Question about Dryers
Removing drum from GE dryer model DDE7900G
Replaced belt and dryer doesn't turn properly can't remove drum
yalmer
  • 552 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
IFIXALL
  • 868 Answers
SOURCE: GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
Posted on Jun 03, 2008
Illeagle
  • 525 Answers
SOURCE: I need to replace the drum bearing on my GE DDE5300 dryer
The idler pulley controls the tension on the belt. Simply grasp the idler pulley located by the motor and pull in the direction of least restraint, then slip the belt off the idler pulley.
Make sure the power is disconnected to the dryer. Below is a link that will assist you with exploded diagrams and parts information.
http://www.repairclinic.com/0100_20.asp
Good Luck!
Dave E. (Illeagle)
Posted on Jun 15, 2008
captaynkyrk
  • 170 Answers
SOURCE: ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Posted on Jul 14, 2008
hektor1961
  • 70 Answers
SOURCE: GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Posted on Aug 17, 2009
How to remove drum from a GE DSXH47eg1ww dryer
disassemble from the front, remove the belt & there you go & if your not sure get a service tech so you dont do more damage
Apr 10, 2014 | GE DSXH47EGWW Electric Dryer
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
How to install dryer belt for a ge model dbsr453gb3ww
  • Unplug the dryer and pull it out from the wall.
  • 2
    Remove the top of the dryer by opening the door and taking out the screws along the top of the opening, then lifting the top. Remove the front of the dryer by reaching down into the opening at the top and taking out the screws holding the front in place. Move the front piece out of the way just enough so you can get to the drum inside, without disconnecting the electrical wires running from the front piece to the unit.
  • 3
    Move to the back of the dryer and remove the screws holding on the small access panel at the bottom. Remove the panel. This will give access to the two pulleys holding the thin belt that runs around the drum. With your pencil and paper, draw a diagram showing exactly how the pulleys are strung. Then slip the belt off the pulleys so it's hanging loosely on the drum.
  • 4
    Return to the front of the dry and pull the belt off the drum from the front. Put the new belt on the drum from the front, laying the ribbed side against the surface of the drum.
  • 5
    Return to the back of the dryer and restring the belt through the two pulleys, using your diagram as a guide. Use your hands to manually turn the drum at least one full turn to make sure the belt is lined up.
    Things You'll Need
    • Screwdriver with multiple bits
    • Pencil and paper
Jan 11, 2012 | Dryers
How to get to dryer drum. GE mod#dbvh520ej2ww
Hello there and welcome to fixya
The most common problem with these are the motor or the motor bearings or rollers
and next is clothes getting caught between the drumb and the shell of the unit
Here is some troubleshooting help for you listed below
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor
Dec 15, 2011 | Whirlpool Dryers
Whirlpool dryer drum doesn't turn. Hear fan motor and gas ignition but drum doesn't move. Tried overide switch on door to verify the drum doesn't move. I am looking for the owner manual but I...
the belt broke,you can buy a kit with the belt,rollers and pulley,change out everything and you'll be good to go.next time send the model number.good luck.while you have the dryer apart,vac out all the dust and lint and if you have a shop vac put it on blow and blow the motor out and clean out the duct that the lint filter slides into,also if your vent line is a long run remove it from the back of the dryer and blow it out with a leaf blower if you have one.
Sep 03, 2011 | Whirlpool Dryers
When I try to turn on my dryer it just buzzes for about 5 seconds and doesn't do anything else. The heater doesn't turn on and the drum doesn't turn. Help!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 09, 2011 | Electrolux EIED55H Dryer
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
Drive belt is broken
You need to remove the front face of the dryer to replace. How to depends on the model.
May 07, 2011 | Dryers
Help!!!
Further dissassembly is required. You'll want to do this anyway to inspect the heating elements. Some of what I say my not apply to your model (because you did not list a model number). 1. Disconnect power to dryer. 2. open door and remove screws going up into the dryer top. (two or four) Usually these are phillips screws, but you may find tri-wing phillips or T-15 torx. 3. swing top back, allowing access to remove the two screws holding the front panel to the side panels. (near the top) 5/16 hex or twin drive (phillips / #2 robertson square drive) 4. tilt front panel forward, lift off and swing to the side. You don't have to remove the door switch wires if you don't want to. 5. Pull drum forward a few inches. (it's a tight fit to get it past the dryer sides) 6. release dryer drive belt. 7. Finish removing the drum.
8. inspect coil heating elements. If one or both have a break in them, you can replace just the coils, you don't have to get the entire big metal part that holds them. 8. Clean and reassemble. (check the teflon rear drum sleeve bearing and the front drum support slides. now's the easiest time to replace them if needed.) 9. put the drum back in, then the belt back on by reaching your thin arms way back to the belt tensioning pulley. The grooved side of the belt touches the drum and goes down directly to the motor drive pulley on the left, then around the tensioning pulley. 10. Put front back on dryer. 11. turn drum by hand several revolutions to make sure the belt is not twisted or comes off. 11. Finish reassemble, connect power and test. You're done !
Aug 31, 2008 | GE Dryers
May 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
