Question about Sony Computers & Internet
Windows Password Problem with Sony Laptop PCG 7190
Need to acquire factory reset CD's or do bios reboot somehow.
  • 21 Answers
The easiest way to reset a forgotten Windows password I ever use is to use Windows Password Reset Deluxe,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
If you want to learn more detail,visit:www.windowspasswordreset.net
It's better than reset password from mode, or create password reset disk,just need a few minutes.Hope it can help you.
Posted on Feb 24, 2012
  • 3940 Answers
SOURCE: Bios password problem Sony vaio PCG-7Z2L
You'll need to contact Sony to reset a BIOS password. You can contact them here:
http://esupport.sony.com/perl/select-system.pl?PRODTYPE=1,24,26,66,9,70,5,72
Posted on Oct 22, 2008
abbeyglobe
  • 21 Answers
SOURCE: how to remove bios password for sony notebook pcg-n505ve
Sorry for that friend. You will have to check the back side of the system and locate the screws to disassemble it. You will see a flat battery quoted silver. Remove this battery and replace it after 5 sec. Assemble the system back and you are done. The password will be remove. Please rate my solution when you are done.
Posted on Dec 29, 2008
Dr Geek MD
  • 201 Answers
SOURCE: i need to flush my bios.forgot password. Sony vaio pcg-7g1m
Try This:
Reseat the CMOS battary:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Posted on Feb 22, 2009
wireman101
  • 61 Answers
SOURCE: who to bypass sony vaio bios password
It is not easy to unlock Sony Vaio Laptops Bios Passwords.
I was searching and i found this
http://www.spunlock.com
They have remote unlock for sony vaio laptops and have been recomended.
Regards,
Posted on Mar 18, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I forgot BIOS password for SONY PCG-GRX520
The best way for the Sony is to remove the cmos battery for at least 30 minutes. Remove the main laptop battery and leave it out. Make sure the power adapter is not attached. The cmos battery can be reached after removing the keyboard and is attached to the motherboard vis a small cable. If you have a "jumper" that come equipped on hard drives to jump the pins on the back, you can "short" the pin connections on the cmos battery socket, power the laptop up using the ac adapter and letting the computer go through the bootup process. When this happens power the laptop back down, take the jumper off and replace the cmos battery. Power back on with just the ac adapter and boot the computer. If the laptop still askes for a bios password just hit enter and it should allow you to log in. Once in go into the bios and reset the date and time. Once that is done power down and replace the main battery. Reboot the laptop and let Windows load.
Posted on Nov 19, 2009
Resetting sony vaio bios pass
Contact Sony for a one-time BIOS password would be your last hope.
Apr 26, 2013 | Computers & Internet
How do I open windows xp on a sony vaio pcg-z505ls if I forgot administor password
If you forgot the password then there are many password recovery tools you can download from the internet.
I will suggest you to download Hiren's bootable cd from the net which contantains powerful recovery and other tools also and it is freeware .
After downloading the hiren's bootable cd you need it burn it into a CD and boot your latop through Hiren's bootable CD.
Inside the CD you'll find password recovery tools which can remove your admin Password.
Hope you know to boot from the CD by changing your boot order in BIOS setting by slecting first boot First Device by slecting CD or DVD.
here is the downloading link http://softarchive.net/blogs/downloaddownload/hirens_bootcd.889895.html
Don't mis use the sofware to break other's password.
Jul 26, 2012 | Sony VAIO Pcg-Z505LE Notebook
ACER 5600 NOT BOOT AND CD DRIVE WILL NOT OPEN
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 08, 2012 | Sony VAIO PCG-K25 Notebook
NEED TO CLEAR BIOS PASSWORD
Hi
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
I would first try resetting using software, here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
CmosPwd - Cmos password recovery tools
Please let us know if it works
May 12, 2011 | Sony Vaio PCG-7F1L PCG-8A1R PCG-8C3L...
I have a probleme of password bios of my lapttop pc sony vaio PCG-V505 AP THINKS
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Mar 18, 2011 | Sony Vaio PCG V505AP Laptop AC Adapter...
Forgot bios password sony vaio model PCG-3A4L
Most motherboards are made with a reset switch. It is a line of three pins, with a jumper over two of them. To reset the bios (completely... everything back to factory settings) you move the jumper onto the other end of this line. Then boot the system up, turn it off again, put the jumper back into its original position and there will be no bios password.
Mar 13, 2011 | Sony VAIO PCG-3A4L Laptop Charger...
I have a sony pcg-grt360 laptop, and I need to install XP from external cd-rom - I can not get into the bios to make the changes to select boot sequence - I need to remove the existing password
Unfortunately this laptop uses the restrictive style of BIOS password. Meaning if you can remove the cmos battery there is a good chance it will not forget the password.
Unfortunately the only way to truly clear it is to replace the whole motherboard which is a nightmare, especially with an older machine like this.
Are you sure there is no way you can get the BIOS password / remember it? I assume that is what is going on, correct?
Please let me know, just reply to my answer here...
Thanks
Tim
Nov 08, 2010 | Sony VAIO PCG-GRT360ZG Notebook
Vaio PCG7ZIL - CAN'T REMEMBER PASSWORD-HELP!!
Log into your computer as administrator to do this. Most likely the password is Administrator, Admin or something like that and the password will be either blank or the same as the user name 'Administrator' or 'Admin'. Once logged in as administrator you can change the computer passwords and users accounts.
Dec 16, 2008 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
