Question about Compaq Presario CQ61-310US Laptop
Does cq61 laptop works without battery
My cq61 laptop doesn't work. when I press start button only the lcd lights glows 3 times. when I press start button with out battery the lcd lights doesn't glow al all.. I want to know is that battery problem or something else does cq61 laptop works without battery thank you
  • mahesh Feb 24, 2012
    I checked the power supply/ power cord with multimeter and it works fine. I even checked the power supply to the motherboard it is also fine. I think it is motherboard problem. If u have any clue pls answer me
    Scholar:
  • 54 Answers
I would assume that the wire/power supply is more likely to be the problem. Even if the battery is completely shot, most laptops will start if the power cord is plugged into the outlet and the laptop is turned on. You should check on replacing the power supply / power cord. Buy it from a store that takes returns with no questions asked. I've even bought one, tested it in the store, (after asking in advance if I could do so). This is a good idea if you live 40 miles from the place it's purchased.
Posted on Feb 22, 2012
  • Dawn C. Weikle Feb 24, 2012
    Motherboard problems could possibly cause such an issue, but troubleshooting that is far more extensive than trying a different power supply. If you're already certain that the power supply is good, then it still wouldn't hurt to try another one just incase something is wrong with it where it connects to the laptop. The port (hole) where the power supply plugs in could also be a problem; does it have any play in it (Does the port move if you press beside it? Does it move while plugging in? Does the cord still fit snugly or not? (Occasionally you can get good readings on a volt meter and still have a problem with that device delivering the voltage to that laptop. You can waste a lot of time troubleshooting if you don't at least try a new power supply early on in the process.)
    Unplug and replug in the power at the laptop (and everywhere in the cord where there is a connection).
    Remove the battery, and hold the power button for 30 seconds. This SOMETIMES clears a temporary problem with power delivery.
    Return power cord and battery, and then try to start it.
    If these brief steps don't resolve your problem I would suggest you try a new power supply from a company that takes returns. There are some universal ones that fit various laptops. Let me know if you want me to recommend one.
    The motherboad is a possibility I wouldn't take completely off the table, but it wouldn't be my first assumption. No one can diagnose it perfectly for you through a forum, just send you in logical direction(s). The actual troubleshooting is up to you.
    IMPORTANT: BEFORE you hold the button down for 30 seconds, make sure you have the laptop BOTH unplugged AND the batttery out so no electricity could possibly get to it during the 30 seconds you hold the power button. (unfortunately I do not see where FixYa will let me edit the post!)
My dell latitude d800 dosnt start. no cursor no splash screen ..only lightning some buttons..
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try. One of these may work on your case.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Sep 03, 2011 | Dell Latitude D800 Notebook
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
Lights come on, but blank screen
Hi estees823,
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
Hope this helps.
Jun 20, 2011 | HP Pavilion dv9000z Notebook
When you hit the on button you only see on screen is black. what's wrong with my laptop?
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite A205-S5809 Notebook
Hp g60, power light comes on, wireless light is orange, charger works ok but wont power up
Hi kr 2583,
Hope this helps.
Jun 11, 2011 | HP G60-230US Notebook
When I try to turn the computer on, battery light flashes four times but computer will not turn on. This happens even when i have the plugged into the outlet
Hi nancy jac719,
Hope this helps.
Jun 09, 2011 | Gateway M-1626 Notebook
My gateway laptop didn't start up,when powered on only black screen appears
Hi jeangray 17,
Hope this helps.
Jun 05, 2011 | Computers & Internet
I just start my computer after that i just paly a song at winnap after that the computer shut down by it self... after that i can on my lap just a green light its glowing ....i am just hepless please tell...
Hi bonny thokch,
Hope this helps.
Jun 02, 2011 | Sony VAIO VGN-NR240E/S Laptop
Hp laptop dv6000 won't start how to solve
I think you can try this step and see if it makes your laptop work.
1. Unplug the AC adapter and Remove the Battery
2. Press and Hold the Power Button for 30 secs. without the battery and ac adapter
3. Put it all back in and see if the machine will work.
If happened it doesn't work. Try this.
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Reseat RAM and Hard Drive.
4. Check if the power port is loosed.
If happens those steps don't work it could be with the Motherboard, CPU, Video Graphics or LCD itself that's having a problem.
Hope it helps somehow.
Apr 25, 2011 | Computers & Internet
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
Compaq Presario CQ61-310US Laptop Logo
699 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
