Question about ASUS Computers & Internet
Asus short battery life - ASUS Computers & Internet
  • ASUS Master
  • 32,281 Answers
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Feb 22, 2012
Why won't ASUS G laptop boot up?
Yes; Batteries at the end of their life cycle do act like that.
support.asus.com/
Jun 30, 2014 | ASUS G Series 17.3" Full HD Gaming...
Tip
Review Asus Eee PC 1101 HA
asus-eee-pc-1101ha.jpg The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
on Apr 21, 2010 | Computers & Internet
My Asus N64vg battery no longer works.
Buy another battery. Batteries only have a useful life.
Apr 22, 2012 | ASUS Computers & Internet
Where do I get a replaement for asus li-on battery pack BA-DI-LMAI, philippines?
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 22, 2010 | ASUS Computers & Internet
I cannot get the laptop to turn on. It came on for a second and now it acts like there is no power but it is plugged in.
Try to hold down the power button. Also check the battery life the device may need to charge. Lastly check the battery make sure its in and secured properly and there is no short in your cord
Nov 04, 2010 | ASUS Computers & Internet
The battery for my Asus Z92KM has become very short lived. If I buy a new battery how long could I expect the computer to run? Could I expect to view a movie of 1 to 2 hours on an airplane?
Hi! Battery life depends on how you use your computer. The normal battery life span is 1 year (more or less, again depending how you use the battery) so if your battery is older than a year you should be expecting to purchase a new battery soon.
Jun 09, 2010 | ASUS Z92Km Barebones Notebook PC PC...
I want to buy asus p552w mobile battery.
Just go to your nearest ASUS dealer in your city & buy the battery.
Feb 23, 2010 | Computers & Internet
Asus Eee PC Series 1000he Battery Life
You can try to completely discharge and recharge a few times to take it through its full cycle. However, you probably won't get much improvement. Batteries wear out with time and, after one year, I'd expect to see significant capacity loss on a machine such as this with typical usage patterns.
Aug 05, 2009 | ASUS P5PE-VM Motherboard
Short battery life
$orry, theres no fix to this, after a while batterys begin to die and the life becomes shorter. this could be due to leaving it on charge all day and night and not letting it frequently loose and gain charge again. even my laptop battery has began to lose its battery length - but ive had my battery for a long time. purchase a new battery and try to keep from leaving the A/C adapter in over night. you should notice alot longer battery length after that. rate me :)
Aug 25, 2008 | Apple MacBook Mac Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
