Code check ink u163 we have just put in a new compatiable color and orignal black ink friday we are not receiving faxes we have all morning and it stop coming thru please advise
Found a substance that i can inject into cartdridge that tricks it into thinkink that it is a new genuine cartridge and not a refil.pete
Posted on Jan 14, 2009
My cannon e600 check ink u163
My E600 check ink u163, press STOP button 5s then press black/color button
Feb 26, 2013 | Canon PIXMA MX310 All-In-One Printer
I refilled the catridge and inserted its showings a message check color ink
Press and hold the Stop/Reset button until the message disappears. You will have to do this every time you insert a "new" refilled cartridge.
Sep 15, 2012 | Canon Pixma Mx340 All-in-one Inkjet...
I have a code u163 code and it also says check ink just put a new black cartrige in and it still has the same code
Darklord1 posted a possible solution here http://www.fixya.com/support/r776805-propper_reset_method.
Or you can try this: Press and hold the stop/reset button for 6 full seconds and then release it.
Jul 23, 2011 | Canon PIXMA MX340 Wireless Office...
The HP Officejet 6500 will now only print color copies, the black copies do not print, the officejet does not recognize the request to scan copies, the officejet will send faxes and show a fax is being...
not ridiculous as the new printer costs less than replacement cartridges
check for ink in the black cartridge
check that the driver is still connected
check for compatibility with the pc
Jun 04, 2017 | HP Officejet 6500 Wireless All-in-One...
Ive replaced black ink cart but it doesnt work,still the message check ink u163 on th LCD.thank you
Either the new ink is a generic cartridge and not reset properly, or one of the other inks is empty. Your display should tell you which ink is empty. U163 just says that one of the inks is empty.
Feb 05, 2010 | Canon PIXMA MX300 All-in-One Printer
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
My brother fax machine is indicating that two color cartridges are almost empty, however i never print anything and color, and basically everything is black. so how can they be almost empty?
Three reasons -
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
May 02, 2008 | Office Equipment & Supplies
407 people viewed this question
jasbo
jasbo
