This speaker is not an active one. This means that it hasn't integrated amplifier, so you need an external one. The cable from the amplifier goes to the speaker. Remove the woofer in order to get access at the inner parts and check these points:
- In case that there is a crossover present there must be a burned out coil or capacitance
In case the cable from the female jacks at the back panel goes direct to the woofer, there must be the woofer destroyed or the cable disconnected. Check the cables, it's less expensive than to replace the woofer.
Post me back if there is a crossover in use or it is direct connected and any other points of interest you came up, in order to guide you further.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
