Question about Ricoh Office Equipment & Supplies
Ricoh 3030 reset photoconductor code - Ricoh Office Equipment & Supplies
5 Suggested Answers
drichards
  • 87 Answers
SOURCE: RICOH PHOTOCONDUCTOR UNIT CLEAR
Actually, there isn't one! But, you can get rid of the message. Press clear modes, 1,0,7, and then press and hold clear stop. Choose copy sp. Scroll to 5, (mode) then scroll to PCU alarm setting. There are 2 options. Display will shut the message off. If it is a 1, make it 0, or vice versa. Interval, will set the count. You can make it an 80, and that will give you 20000 more prints. Personally, I would change the PCU really soon, other wise you will pay for it in toner.
Posted on Mar 19, 2008
  • 400 Answers
SOURCE: Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 01, 2009
  • 1126 Answers
SOURCE: ''Replace Photoconductor'' on Ricoh 1022
They are rated at 60,000 copies....it depends on where the end counter is set at before it fails, Approximately 500 to 1000 maximum copies before complete failure.
Posted on Oct 15, 2009
  • 903 Answers
SOURCE: I am working in ricoh
Hi, the message automatically goes away when you install the new photoconductor unit. Until you install the new unit, the message will remain on the screen, but it won't affect operation at all -- you can still use the copier just like normal; that message will just keep popping up.
The machine keeps a counter for how long the photoconductor unit has been in use, and around 60,000 copies or so it displays that message so that you know to replace the unit soon. You can keep the old unit in as long as you want, but eventually you will probably start to see a degradation in copy quality -- faint lines, spotting, dirty background, and/or light copies.
If you don't already have a new photoconductor unit on hand, the EDP code if you want to order one is 410423. I would recommend getting a genuine Ricoh photoconductor, because third-party units have been known to create problems on occasion.
Thanks for using FixYa!
Posted on Feb 02, 2011
Aficio sp410dn error code sc362
sc362 is the cyan (blue) photoconductor unit error code. Replace the cyan photoconductor.
Jun 20, 2014 | Ricoh Aficio SP C410DN Laser Printer
Sc542
fuser problem needs fix and then reset code
Mar 04, 2014 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Our Gestetner DSm415pf printer has a photoconductor light on, needs to be replaced. Where do we purchase this and how do we find out the method to replace this. Manual? We don't have.
It's very easy to replace the drum unit. When you find Photoconductor unit there is a simple instruction on the box. You have to search for photoconductor unit type 1515 (also look for nashuatec, rex rotary, infotec or ricoh brands to see where you can find it on best price - 100EUR).
If your mashine is printing fine, there is no need to replace the drum. You can only reset PM counter display if mashine stops.
all the best
pifonski
Apr 07, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Jun 28, 2009 | Ricoh Aficio 450 Copier
Replace photoconductor message keeps appearing
Reset it .
If you are enter service mode 5-912 default 60K just input Zero "0" this will deactivate the PCU counter.
If it is bad you will have to replace it. It is the Photoconductor(Drum / Developer) Cartridge
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Aug 26, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
373 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
