Question about Acer V193w LCD Monitor
Input not Supported
Black screen, floating gray box Input not Supported, I am sending this message from my laptop.
  • banner97 Apr 02, 2009
    floating input not supported (grey) box floating on screen.
    Acer x173w
  • Anonymous Mar 25, 2014
    TV has floating grey message
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Input not Supported? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
8921EQIX 715G3350 1 2 Acer ADTV8921EQIX Power Supply Backlight Inverter
Posted on Dec 12, 2014
  • 35 Answers
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Posted on Oct 27, 2008
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
How do i recovery acer aspire 5672WLMI laptop back to factory settings? I try <alt> and <F10> method but it only sends me to a black screen with gray writing and has nothing to do with rec
Shut the computer off and then power it up again. As it is starting press the shift button and F10 and hold. You should get a warning that you are about to reset your computer select yes.
Keep in mind that once it does the reset all previous windows updates will be lost and need to be down loaded and installed through windows update again. Windows XP is no longer supported so not sure if all XP updates are still available.
Apr 30, 2014 | Acer Aspire Computers & Internet
Floating gray box that says input not supported
When do you see the grey box? When you are playing a game? If so, try changing the resolution on your screen through the Control Panel...personalization...the resolution scale. You may need a lower resolution in order for the game to be played. I used to get a box that said "signal out of range". It wouldn't go away until I lowered the resolution in order to play that particular game. You can always change it back to your original resolution. Did you have a message in the grey box.
Mar 20, 2012 | E-Machines eMachines Desktop PC
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Graemevm
Dec 15, 2009 | ZT Group Cisnet PC Desktop
During setup, got a "INput not supported" message
Reboot the computer and enter into Safe Mode through pressing F8 repeatedly on the keyboard.
If Windows will not come up, then you have to access the system through system restore.
In windows xp, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\restore\rstrui.exe
This is done through Safe Mode with command prompt or command prompt; depending on the operating system.
Aug 08, 2009 | Acer AL2016W 20" LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from rma@rosewill.com.
Hope this will help you.
Ringo
Dec 13, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
Jun 28, 2007 | Acer AL1916W 19" LCD Monitor
Acer V193w LCD Monitor Logo
573 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
