Question about Kenmore Washing Machines
F1 error codes
Does not do anything.
    Sergeant:
  • 316 Answers
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Whirlpool WFE381LVB gets F1 error code
    F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
    Feb 27, 2012 | Whirlpool Electric Range
    Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
    "F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
    Thank you !!
    May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
    My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
    There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
    Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jan 08, 2010 | Kitchen Ranges
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    "F1" error code on Magic Chef gas range Model 3488XRA
    the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
    Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Washing Machines Logo
    136 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
