How do you fix the color resolution on a Philips DPTV 335 HDTV after a AGP 8X graphic card was installed then routed through a desktop PC to the DPTV 335
Color resolution is ok when tv is on, but when the pc is on to watch movies through it wont adjust. A 6 in DVI cable was also added.
  • 3,799 Answers
You set the resolution on your computer not your tv. The computer is the control of the video output.
Posted on Feb 24, 2012
sparky1500
  • 1066 Answers
SOURCE: Graphics card support to motherboard Intel D845GBV
should work good
Posted on May 17, 2008
MORRISS
  • 40 Answers
SOURCE: Unable to get 1440 x 900 resolution with onboard graphics.
Yes, through bios you can only select VGA but it wont have any effect on what you see on windows, so let bios aside. Is through Windows Display properties that you select all the different resolutions... (RIGHT CLIC YOUR MOUSE OVER THE DESKTOP, SELECT PROPERTIES AND LOOK FOR THE SETTINGS TAB ON TOP, MOVE THE SLIDER AT THE MIDDLE TO SELECT RESOLUTIONS) in windows is where you should have the latest drivers from ECS (now PCCHIPS) for your motherboard's onboard graphics. 1440x900 is widescreen type resolution, only available rather recently by new monitors that support it and so I guess it wasn't included in your original motherboard driver CD. Then it's a must to have the new drivers installed and the monitor's plug and play recognized by windows in order to attain the desired resolution from the card.
Any new AGP video card will be far better than the onboard type. DVI is just a digital type of conector and doesn't have to do with the resolution selection, but it will make the images in the monitor show a little better since there is no signal degradation in digital transfer through the monitor cable.
Posted on Jan 04, 2009
IPOD tech
  • 61 Answers
SOURCE: Graphic Card driver
i think you can download it from the link below if it does not work get an account it is free you can download it then.
http://members.driverguide.com/driver/detail.php?driverid=200474
Posted on Feb 23, 2009
marked
  • 6487 Answers
SOURCE: where i have a installation Nvidia GeForce FX 5500
You can download the video card driver from this link
http://download.cnet.com/NVIDIA-GeForce-FX-5500/3000-2108_4-64419.html
Posted on Apr 22, 2010
joecoolvette
  • 5660 Answers
SOURCE: i need Nvidia GeForce 6600 / 256MB DDR / AGP 8x /
I would suggest this instead,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4803129&CatId=2234
It will far surpass the graphics quality of an Nvidia GeForce 6600 series graphics card, and will use less power.
If the above specifications are for a particular game you're trying to run, this video card excels past the minimum required specifications for the game.
1) Has 512MB of GDDR2 ram memory
2) 128 bit Memory Interface
3) 120 Stream Processors
4) Two DVI port ports
5) TV-Out (S-Video) port
Doesn't matter if you use an Nvidia graphics card, or an AMD ATI graphics card on your computer.
What matters is if it is an AGP graphics card, (It is), and an AGP 8X graphics card. (It is)
Regards,
joecoolvette
Posted on Dec 02, 2010
Help with upgrading Dell Dimension 4600 GPU
June,
The Dell Dimension 4100 Desktop PC, utilizes an AGP slot on the motherboard, for a graphics card.
http://en.community.dell.com/support-forums/desktop/f/3514/p/17152514/17275500.aspx
There are different styles of AGP expansion slots.
The one on your motherboard was the last current style of AGP -
AGP 8X
Therefore your Dimension 4100 uses an AGP 8X graphics card.
It is (Was) an Nvidia GeForce FX5200 graphics card, and the AGP 8X style.
http://en.wikipedia.org/wiki/AGP
To replace it just use a graphics card that is AGP 8X, and is better, or equivalent to the GeForce FX5200.
You also need to know that your Power Supply in your computer, will handle the power requirements for the computer system, AND your new found AGP 8X graphics card.
Power Supply was rated, at a maximum Wattage rating of 200 Watts.
Problem is; that back in the day when the Dimension 4100 was made, the Power Supply manufacturer 'Fudged' the real Wattage specifications.
Power was (Is) more like 60 to 70 percent of what is stated.
Divide 200 Watts by 10
= 20
Now take that times 6, for 60 percent.
= 120 Watts
Now take that times 70, for 70 percent.
= 140 Watts
ACTUAL power
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4410189&CatId=2234
I would recommend this one, but it requires 250 Watts MINIMUM,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=853908&CatId=2234
[Graphics card manufacturers, base the Minimum power requirements for their graphics cards; based on a test computer system.
So the Minimum power requirement stated, is not only for the graphics card; but ALSO the rest of the computer.
The test computer system is usually based, on all of the top of the line, power consuming hardware components; of that time
Top of the line powerful Processors, and Motherboards.
Add to that the maximum amount of Ram Memory, that can be used.
Two optical drives, (CD/DVD drive)
Processor fan, and at least two computer case fans ]
KNOW THIS:
A) FOLLOW Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, and BEFORE taking any new parts out of their Anti-Static bags, or cartons.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return
B) Windows running on your computer, PUT the Installation disk that comes with the graphics card, in your optical drive tray.
(CD/DVD drive)
Install ALL software.
There will be Drivers you are installing, and also a graphical user interface. (GUI)
The GUI for an Nvidia graphics card, (Evga GeForce 6200 is an Nvidia card), is the Nvidia Control Panel.
(For ATI it's Catalyst Control Center)
Driver: Small piece of software that allows the Operating System to communicate with a device
In this case the device is the graphics card.
What version of Windows operating system was not stated.
-> AFTER <- you have installed the software, and if it asks you do you wish to restart your computer; the answer is -> NO
Close all windows, go back to your desktop screen.
Now turn the computer off normally.
Follow Anti-Static Procedures, and Physically install the graphics card.
Note*
The AGP expansion slot on the motherboard, will have a type of Locking Arm on it. With most the end of the arm, has a 'fingerdip' in it.
Makes it look as though you press DOWN, on the end of the Locking Arm, in order to release it. (Unlock)
Actually you GENTLY pull up a little on the PLASTIC Locking Arm, to release it.
Release to remove the old graphics card, and to install the new one.
After the new graphics card is installed, attach the monitor cable to it, and close the computer case.
Turn the computer on.
You MAY have to go into the Nvidia Control Panel, and set Screen resolution, and other parameters.
(Look up your monitor by it's manufacturer name, and model number. {Back of monitor - Model Number}
See what the Screen resolution is.
Example - 1280 x 800 pixels
Set Color quality to High (32 bit)
Have additional questions please post in a Comment, or Reply.
(Below my solution)
[When a device is installed on a computer with Windows, Windows will 'break it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = NO
A Driver Conflict can result.
Windows: "Which drivers do I use? These or THESE?"
With THE drivers installed first, Windows will find them.
May 06, 2013 | Dell Dimension 4600 PC Desktop
What graphics cards can i use on this pc?
Hello
Although the system is not a new one to use PCI express card but you can use any AGP 8x Graphic card.
My recommended AGP 8x graphic card is eVGA e-GeForce 6800 GT/ultra 256 MB.
Hope this helps
Feb 02, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
Hi my graphics card went out on my hp a620n desktop i was wondering if i had to get a specific type of graphics card to replace it. Any assistance helps!
i tought you were dead since it has an integrated graphic card, but it seems you have an expansion agp 8x slot.
you can buy a hold agp 8x graphic card for it.
anyway as a personal suggestion, don't buy a 100$ card for a pc that whose vlue would be arround 50$... buy a new cheap pc the would be enormously better than this!
Jun 11, 2010 | HP Pavilion a620n (PC028A) PC Desktop
What AGP graphics card is compatible with AGP
AGP 4X (1.5 Volt)
http://www.firingsquad.com/hw/1719/Iwill_P4S/
Suggest you use a graphics card that is AGP 4X/8X
Example, ( Not an advertisement for graphics card manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Jan 14, 2010 | Computers & Internet
Powercolor x1650 512mb AGP problem
The one you bought is 16x but your MB supports only 8x..................sodeep
Jun 18, 2009 | Power Color 256MB PowerColor ATI RADEON...
Problem with graphic card
Here is a link to all the drivers. It is a Via VGA P4M800CE video chipset
http://www.mercury-pc.com/product-drivers.php?productid=677
Dec 01, 2008 | Computers & Internet
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
How to properly install Asus N6200 AGP video card
Set refresh to 60hz
Set color to highest position.
If this is an LCD, set it to the highest resolution
If this is a 15" or 17" CRT, set resolution to 1024x768.
If this is a 19" CRT, set resolution to 1280x1024.
Also, do not use the drivers on the CD. Go too nvidia.com and download the latest there.
Also, if you can get into the BIOS, try to disable the on board graphics if you see an option for it.
Oct 30, 2007 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
Compaq s4020WM AGP Questions
I don't think there's a 8x AGP card made that would not work at 4x, and any 4x capable AGP slot should handle an 8x card. AGP 1.0 (x2) signals at 3.3V AGP 2.0 (x4) signals at 1.5V AGP 3.0 (x8) signals at 0.8V
Apr 05, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
