Question about Ecoquest Breeze AT Living Air Purifier
My machine needs an overhaul?
My machine makes a high pitch noise. a screw works itself loose every month i notice when i clean it . it will only accept one plate on the left side, the other side will start arching. does not give off the ozone odor.
  • thewaygirl Mar 07, 2009
    Mine squeals, it is like the fan needs lubricant. The fresh air smell is still there, I've cleaned the plates and fan blades but wonder if dirt/dust has lodged itself behind the fan blade part. It looks like the fan itself is secured with a cotter pin type device and I'm terrified to pull it off and not be able to get it back on! Help! We love this purifier, it has been awesome for us!
  • 80 Answers
Contact healthytech@triad.rr.com. They will be glad to help you.
Posted on Jul 14, 2009
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Tip
Brookstone Pure Ion
We had a problem with ours, it kept telling us the filter needed cleaning, though it had just been done and was actually fine. It would sound a high pitched alarm and "freak out" on us.
We found using a shop vac and cleaning it out all (while unplugged, of course) inside where there are intakes and general insides was greatly helpful. It was making a crackling noise as well, quite often.
We have asthma and allergies in the household and rely on this to help our family, it's a wonderful thing to own, we love it.
But, this one problem had us stumped. Do try to use a powerful vacuum and really get inside. We have cats and apparently cat hair as well as household dust was clogging it. You obviously need to do more than clean the filters, themselves, from time to time.
on Mar 21, 2008 | Brookstone Pure-Ion UV Air Purifier
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
The orange tape on the bottom of the ionization bars
There being two strips of orangey tape at the bottom of the rods wipe clean the two thin wires stretching the length of the ionic breeze each time you remove the filter elements to clean the filter. Seems like these wires may be emitting the audible high pitched noise if dirty.
Frank
Jul 12, 2008 | Sharper Image Ionic Breeze 3.0 Air...
After a few months, the device makes a very high pitched noise that is irritating to those who can hear it (me). It still seems to work well, but I want to know if this can be addressed.
Inoic Breeze machines are no longer being supported because Sharper Image went into Chapter 11 as a result of the products proven to be ineffective by Cosumer Reports and studies conducted by the EPA.
Here is the Sharper Image article
Here is the EPA article
Jul 12, 2008 | Sharper Image Professional Plus Ionic...
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Jan 12, 2008 | Ecoquest Fresh Air Air Purifier
Not running quietly
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jul 25, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ecoquest Breeze AT Living Air Purifier Logo
203 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
