Question about Tools & Hardware - Others
Need manual for stapler air ace f509040
Air ace f509040-cb310 stapler need manual got used stapler and have no manual want to know how to adjust it.
    Top Expert:
  • 52,086 Answers
Search for manual thru Google
Posted on Nov 24, 2015
3 Suggested Answers
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
jeff_drakesr
  • 155 Answers
SOURCE: I bought a used item #f509040 brad/staple gun (Air
The nails fit one side same place as the staples its usually on right side but may not matter. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Posted on Apr 03, 2010
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Jan 09, 2011 | Ace Hardware Ace Staple Gun
I bought a used item #f509040 brad/staple gun (Air Ace) It came loaded with staples. How do I load nails??
Apr 03, 2010 | Ace Hardware Ace Staple Gun
Can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Dec 24, 2009 | Ace Hardware Ace Staple Gun
Got a black and decker electric stapler given to me but no manual so can't find way to load it. It is a cat. no. 9700 stapler
Look at the back of the staple gun just under the electric cord and you will see a 1/2 loop of spring steel sticking up from the chrome base. Push it down lightly and toward the front of the stapler - when it is all the way forward lift the loop it while in the forward position and while up - draw it back and the will come out of the staple gun.
Sep 29, 2009 | Black & Decker Tools & Hardware - Others
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
I have a stenco sns 41 stapler that double fires and then jams.
Make sure your air is regulated down to the right pressure ( usually 80lbs. ) also there is a way to staple without double firing and that is to hold finger on trigger and tap gun like a hammer but a lot lighter.You can also adjust the safety on the nose of the gun. I believe there is a screw on the front side to loosen and adjust the safety. As far as the manual, just go on their website and get on to download, because they are free always.
May 26, 2009 | Senco SNS41 16Ga Stapler 1" 2"
Stapler!!!!
The most expensive stapler ACE sells is $35-ish. If something is broken or if you can't get it back together, you may need to replace it.
Apr 09, 2009 | Ace Hardware Electrical Supplies
Tools & Hardware - Others Logo
587 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
