Question about Thermador MBES Microwave Oven
Microwave shuts down after 3 seconds thermador mbes/01
The microwave shuts down aftera few seconds and goes back to clock
MicrowaveSvc
  • 9047 Answers
SOURCE: Thermador MBBS/01
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
Posted on Nov 28, 2007
SOURCE: Thermador MBY microwave
The problem is the push-on connector on the UPPER door-latch switch; if the white plastic around this connector is brown (burning), the connection is going bad.
Cut the three white wires back about 1 inch and strip; obtain a new push-on and solder the three white wires into it-- a crimp is NOT sufficient for three wires into this little connector (defective design). Also clean the two blade on the switch before reconnecting as the heat has likely left a burnt coating.
Posted on Jun 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: thermador microwave from oven/micro/warming drawer
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Posted on Aug 21, 2008
SOURCE: TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Posted on Sep 15, 2009
heatman101
  • 43501 Answers
SOURCE: thermador built in microwave turns
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Apr 02, 2011
Microwave shuts down after 2 seconds
unplug the appliance from the main socket and plug it after sometime
Jun 07, 2013 | Thermador MCES MCEB Convection Microwave...
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
REPLACEMENT MICROWAVE FOR THERMADOR MBES
That is good to know, some brand names will soak you just for their company logo.
Apr 22, 2012 | Thermador MBES Microwave Oven
Thermandor Microwave MBES is shutting off.
That is a possibility but there other parts that can come into play, a bad magnetron " filiment sometimes opens" high voltage diode " sometimes cracks and developes a high level short, and finally the high voltage capacitor " will normally short" I do recommend a professional in this case.
Mar 07, 2012 | Thermador Microwave Ovens
Clock runs, but breaker trips immediately when time is set and start are pressed.
Panasonic type s333 is the same model. We bought a new one at Sams Club $148. Took off the trim kit a pulled out the old and replaced with the new. Look at the inside of your door to see if youhave the same model with Themador lable
Jan 30, 2012 | Thermador MBES Microwave Oven
MY displat shows a Child Lock problem. I find nothing in the manual about chikld lock. How do I unlock?
Manuals for some Thermador Microwaves are available here: http://www.thermador.com/trade/specifications-guides . Scroll down to Microwaves and select your model. Then press the link for Product Manuals and then choose the manual.
On the
MBES and MBESLFTD, the child lock feature is unlocked by pressing Settings 5 2 (touch each pad/number once).
If you have a different Thermador microwave, I'll check my stack of manuals for the specifics. (On a few other brands, the child lock can be toggled by pressing and holding the Start key. One of my other microwaves has a small padlock on the key to indicate the correct key. With that toggle, press and hold the key for 3-4 seconds or longer.)
I hope this helps.
Feb 19, 2011 | Thermador Microwave Ovens
The glass plate inside will not rotate
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
Thermador MBES Microwave Oven Logo
453 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
