Question about Sharp AL 1631 Copier
Black toner coming out on full length of copy
I have already cleaned unit and problem is reoccurring, could I have a defective sharp toner cartige that is leaking toner out causing this problem?
  • michaelwa Nov 05, 2008
    Same problem on my Sharp AL-1631 copier. I emptied out the used toner, then installed a new toner cartridge, but toner is still dumping inside machine and onto right side of copies.
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Is problem solved
Posted on Oct 30, 2008
Sharp 1641cs - Dark/black page after replacing drum & toner
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Jan 11, 2013 | Sharp AL-1641CS All-In-One Laser Printer
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
Aug 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp ar-m257 copier. my copies were
There are a few thing's > have you cleaned the optic's > clean the primary charge unit in the drum unit > how old is the drum & developer? Also, is the copier calling for for "Maint's Req"
Apr 05, 2010 | Sharp AR-M257 Black and White Copier
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
The copies comes out totally black
H2 00 Thermistor open, your fusing unit needs to be serviced (cleaned or replaced)
The black copiers can be a number of things a few things to check and what the remedy could be;
  1. Open the right door, if you notice a lot of toner/developer spilt then you could be having a charge corona short (built onto the drum unit) clean corona
  2. Open the right door, if you drum (green or blue cylinder (depending on brand of drum) under your fuser) is coated with toner (should be all green/blue) then you could be having a drum short, replace drum unit for this.
  3. Open the right door and on the door towards the bottom is a metal unit with a white guide built on it (transfer corona) if there is a lot of toner/developer in it (looks dirty) then this needs to be cleaned or re-built.
  4. You also could be having a board issue causing the black copies.
Mar 26, 2009 | Sharp Office Equipment & Supplies
Toner dumping
check under the drum, if there is excess toner there it is most likely coming from the drum unit or the cleaning unit, this is a unit that is on the drum and is supposed to remove any excess toner and dump it into a waste container. it may be full or blocked
Dec 18, 2008 | Sharp AR-M208N Copier
Copies have a void area the length of the copy approx 1 inch wide
pull out your toner unit and look at the front to see if there is a missing spot on the roller where there is no toner. if not you probly need a new drum.
Nov 12, 2008 | Sharp AL 1631 Copier
Toner cartige
clean the roller. the toner you have installed may be defective.
did you have the same black squares before you change the toner???
Oct 29, 2008 | Brother HL 1440 Laser Printer
Toner collecting containr of transfer unit
Remove the toner bottle and look for a black sensor. Clean it. Clean out all the toner in the bottle and try copying on it.
Oct 01, 2008 | Sharp AR-C160 Color Copier
Sharp AL 1631 Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
