Question about Salton Coffee Makers & Espresso Machines
Need replacement cutting blade for Salton coffee grinder #GC-6
SOURCE: Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Posted on Aug 24, 2007
  • 4 Answers
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
SOURCE: Replacement coffee carafe
I have a complete Salton Three for all EX20 I'll be listing the carafes on e-bay soon.
Posted on Feb 06, 2008
SOURCE: Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Posted on Jun 26, 2008
  • 74 Answers
SOURCE: Instructions
http://www.coffeecrew.com/content/view/186/27/
http://www.coffeecrew.com/content/view/187/27/
found these two links right here on Fixya.
Sry to say it seems that most people that have actually got a manual is from Salton.
Email them and they will send you a .pdf of the manual.
info@salton.com
Posted on Jul 18, 2008
Salton quick mill disassembly
last four digits of phone
Jun 20, 2013 | Food Processors
In the past I have cleaned the grinder blades 4 times however this time I noticed some of the grind mixture winds up on the counter under the main motor of the unit. When I picked up the grinder and shook...
Have you tried to hoover up the grinds from time to time, from the grinder blades. The coffee beans and ground can gather under the blades from over time. It should not be a problem though.
For better crema you may want to replace the blades.You should replace every 3-6 years. Rancilio Rocky Grinder Flat blades
May 07, 2017 | Rancilio Rocky Doser Espresso Grinder...
Motor for grinder is functioning but the blades are not cutting or rotating.
Hi
You need to replace the grinder. It has probably exploded inside. Sorry, they are usually very dependable grinders. I have a new 1 if you want to replace it.
Dec 20, 2009 | Saeco Royal Professional Espresso Machine
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Don't know how to use Mr.Coffee IDS57 coffee grinder
Typically you load in the beans, replace the cover and then either press down on the entire cover or the black knob on the front of the cover. I would hold the lid down with your other hand just to be safe. Grind for about 4-6 seconds depending on how strong you like your coffee (the longer you grind the finer the coffee will be...this means STRONGER)
Jun 09, 2009 | Mr. Coffee IDS57 / IDS55 Electric Blades...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Salton perfect touch electric grinder - thermal switch/fuse
This is most likely a thermo overload, and can be replaced, make sure that there is no short circut before replacing it, as it will only blow again if there is a short. This part can be purchased at any Radio Shack store.
Jan 26, 2008 | Salton Perfect Touch Electric Blades...
Blade replacemen braun grinder
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
How does one order a replacement grinder cover?
you can now order a replacement filter basket for this coffee maker. The price is $8.50 plus shipping and handling. Just call customer service at 1-800-233-9054.
Dec 09, 2007 | Salton MEMB1B
Coffee Makers & Espresso Machines Logo
85 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
