Question about Canon BubbleJet i560 InkJet Printer
Error message 5100 on Canon i560 printer
I tried to print a document in MS Word. It had some color graphics and an orange background. I got an error message saying Service error 5100 and telling me to cancel the print job and turn the printer on again. The green and orange lights were flashing once alternately. When I tried printing again, the same message appeared. I tried it a couple of times, and even cleaned the print heads and checked the nozzles and print alignment. The printer also made a screeching sound when it started to print the page.
I just printed out a letter in black and white and it looked fine. What's causing the problem?
  • 4,041 Answers
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
I have a cannon printer mp160. I'm trying to print a document but I keep getting a service error 5100 message
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day.
Nov 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer problem
Have you tried checking ur applications for permission to print what you are trying to print......Or it could be a document you can not print
Sep 29, 2009 | Computers & Internet
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Mar 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
393 people viewed this question
old marine
old marine
