Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
My heater will not lite
I just moved in this house and I am trying to turn on the heater for the 1st time. It said on the lable that is was a GPD8 75-3 REV. It blinks 1 time after trying to start. I made sure that the tube to the roof was clean. I see no flames, it said it does not have a pilot light. What do I do? Thanks
  • 34 Answers
Check to make sure the gas is on to the house, and the furnace.
Posted on Dec 01, 2008
I keep getting a Paper Jam message even after calibrating many times. Am using continuous roll of 1 X 4 lables. Was working fine until I tried to print another set of lables. What Gives? Am using a...
2 x possibilities.
1. sensor may need moving to to see label edge (green knob at RHS)
2. possible sensor faulty. Only testable by substitution.
Jul 06, 2011 | Toshiba TEC B-572 Printer
How do I access the interior map lamp housing and remove to replace a lamp?
You need to remove the overhead console to get to the bulb holder.
Open the rear compartment, and pull down grasping the rear corners with your finger and thumb.
The 1st time you pull it down is hard, the spring clips do not move that easy the 1st few times.
Once the rear releases, you can work your way around the console, pulling loose the spring clips.
The bulbs are held in from the back using 1/4 turn bulb holders.
Dec 21, 2010 | 2006 Ford F-150
I have an older Miller Furnace in a mobile home that I own. The unit was made around 1977-78. Think the model number is MGC-80-1. It does two things that seem odd. 1st is it will kick on like it should,...
sounds like the fan control is playing up try cleaning the back of it could have dust in it cleaning my help fan could be a loose spindal which the fan spins on see if this helps
Nov 06, 2010 | Heating & Cooling
I hav e2004 nissan altima my heater is constantly blowing when turned on but only blows hot when car is moving or u rev motor
Sounds like an air pocket, make sure your radiator is completely full, should be an air bleed valve by thermostat housing to bleed air with engine off when filling radiator.
Jan 05, 2010 | 2004 Dodge Ram 1500
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Heater Core
1) disconnectnegative battery cable
2) remove coolant reservoir
3) dis-connect heater hoses from heater core and plug holes in heater core, some coolant will drain out
4) remove mounting bolts and nuts on fire wall
5) remove glove box liner and door
6) lable and dis-connectheater controls
7) dis-connectand remove computer and mounting bracket
8) move radio antenna wire
9) remove kick pannel and un-bolt lower corner of dash
10) remove screws and nuts holding the housing inside the cab
11)remove the heater housing from the vehicle
12) detatch the core retaining straps and remove the heater core
13) installation is this procedure in reverse
I hope that this fixes your problem good luck and please take the time to rate this response.
Oct 17, 2008 | Chevrolet Suburban 1500 Cars & Trucks
91 Ford Ranger 4 cyl 5 speed. Can`t find clutch slave cyl. bleeder. Internal slave. Hard at times to get into 1st and rev. Also can`t find connector to hook up tester for check engine light on.
first the bleeder will be located on the cylinder that is mounted on the transmission to engine connection by the bell housing. Second the port for this is located along the drivers side under the hood either by the fire wall or along the top of wheel well it will be marked with a grey cap labled EEC.
Aug 28, 2008 | 1991 Ford Ranger Supercab
Heating & Cooling Logo
69 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
