Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line diagram poulan pro 260
Is there a diagram on where the fuel lines go?
SOURCE: gas line diagram for poulan 2050 2.0 CI '97
Gas line diagram for poulan 2050 .
Posted on Oct 25, 2009
  • 12 Answers
SOURCE: I have a poulan pro 220 16"
Carb has 2 inlets top inlet connects to tank line with filter on it. Bottom inlet connects to bulb other line from bulb returns to tank on bar side.
Posted on Mar 15, 2009
dontbother10
  • 2220 Answers
SOURCE: I NEED A DIAGRAM OF THE FUEL LINE TO THE
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
e17de8d.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Posted on Oct 29, 2009
studio500
  • 36 Answers
SOURCE: need a diagram of the
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Posted on Apr 17, 2009
SOURCE: NEED A FUEL LINE DIAGRAM FOR POULAN 2250
The smaller size line comes out of the tank, leave enough to install filter on that line in the tank, this line goes to the intake side( I think it is the right side of the carb when it's mounted in the saw), of the carb. The other smaller line goes from the other side of the carb to the primer bulb. The larger line goes from the other side of the primer bulb back to the tank, it only has to be pushed in the tank about 1/2 to 3/4 inch. The large line goes in the tank in the hole on the right side unde the carb. The primer bulb has different size nipples. I just put these on mine, it's hard to get the lines in the tank, I sprayed mine w/wd40 and just pushed them in until I could pull it with some needle nose pliers or hemostats.
Posted on Apr 29, 2009
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
Diagram of fuel lines poulan pro blower
Put your model number into goggle and search for a fuel line diagram and you should be able to find what you are looking for. Hope this helps.
Oct 03, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
Replaceing fuel line and primer bulb in a poulan pro 260
ACE Hardware has everything you need, I have the poulan also and all you need is the torx screw driver and get the little clamps for the fuel line, I got the kit which had all in it...good luck.
Aug 05, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan 260 pro starts and runs for 15 - 30 seconds and then dies. I have changed spark plug, replaced fuel filter, checked fuel lines. Any idea of what could be the cause?
If you have changed the fuel filter, and the hoses are not leaking, then you may well have a blockage in the internall filter in the carb, the filter is under the alloy pump cover, usually secured with a single screw.
May 14, 2011 | Poulan Garden
Were can i get a diagrame for a polan pro 260 chainsaw
You can find diagrams for the Poulan Pro 260 here - http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-260TYPE13/1324/1503220?blt=05.
Please note that there a few different "Types" of 260, so if this isn't the one you've got, try selecting "Poulan" from the Brands list at the top of the page and then looking through the available models until you find the "Type #" you have.
Sep 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas line
What little fuel system detail ther is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find a model number that matches your saw.
Fuel lines run from the tank to the carburetor to the purge pump and back to the tank. Take extensive notes and a few digital photos as you go are a good idea.
SmallEng.com
HTH
Lou
Oct 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
6,005 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
