Question about LaCie Big Disk (300872) 400 GB Hard Drive
400 GB LaCie drive does not accept anything
Dear Sir; I am running a iMac G5 Mac OS system 10.4.7 and a 4 month old 400 GB LaCieDrive. At first it funcioned properly. But I had to put with Disk warrior a new Directory and my MAC HD worked fine again but not the LaCie drive. I formatted it again and it shows on the desktop, Whenever I try to copy something to it I am getting error messages. One is Error code -36 And when I tried to remove the ghost from the drive I am getting error -50. The drive does not show up with its characteristic LaCie icon. At first I got reactions like that the name of the item was to long. How can I repair this? I could not find anything in your help department. Thank you, Alex den Ouden - Bloemendaal 19 Bergen op Zoom Netherlands tel 31164263926
3 Suggested Answers
  • 42 Answers
SOURCE: help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Posted on Dec 09, 2007
  • 82 Answers
SOURCE: my lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Posted on Aug 21, 2009
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
Jun 24, 2011 | Apple iMac G5 Desktop
My Plexwriter 12/10/32A works flawlessly on my old G5 PowerPC Mac running Mac OS 10.4. However, when I plug it into my new iMac 27 running 10.6, using an adapter cable (Plexwriter has a Firewire 400, the...
I have always understood that FW 400 is not fully compatible with FW800. Although slower, does it have a USB connection on the disk caddy to test it?
Jan 16, 2011 | Plextor PlexWriter CD-RW Burner
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Isight intermittent. G5 Imac 17" The Isight cam I have now dubbed 10sec cam turns off and has to be restarted.
I understand from your problem statement that the internal iSight camera in your G5 iMac turns itself off around 10 seconds after you turn it on.
Create a new temporary user in System Preferences / Accounts. Log out and then log in as this user. Enable the camera. Does it still turn off in 10 seconds? If not, something running in your other user account (a startup program or system preference) is interfering with the operation of your camera.
If you have a spare external drive, install a fresh version of the Mac OS on that drive, then boot from that drive. Does the camera still turn off in 10 seconds? If not, you should run an OS installation with "archive and install" on your internal drive. If it does, you have a hardware problem that requires a Mac tech. If this is indeed a G5 iMac, the repair will likely not be cost-effective.
Aug 26, 2009 | Apple Computers & Internet
While trying to install OS10.5 and it will attempt to but it freezes, you the Apple booting circle it stops.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
May 20, 2009 | Apple Computers & Internet
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Imac g5 model:a1058
iMac G5's cannot run windows alone, but older software can be purchased like Virtual PC to run windows on that unit.
Aug 05, 2008 | Apple iMac G5 Desktop
Lacie 150 running on Imac G5 Tiger 10.4.11
Hello, I assume that this is a FireWire external drive. Do you have any other FireWire devices (another drive, older iPod, etc) that you can test the port with? If other devices work, then the port on the drive has malfunctioned, or the drive needs repair (try Disk Warrior or First Aid in Disw Utility within OS X Applications...Utilities). If those other devices don't work either, then the port on the computer may be the problem (meaning logic board). You can also try creating another user in OS X, and testing the ports and the drive under that user. If all is well as another user, then you may have a software issue in your own user account.
Jun 13, 2008 | LaCie (300728U) 250 GB Hard Drive
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LACIE DRIVE NOT READING
try going to the manufacturer web site for the make of the hard drive
find a download for that model and select mac as the operating system\
download and run
Dec 02, 2017 | Computers & Internet
LaCie Big Disk (300872) 400 GB Hard Drive Logo
48 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
