Question about JVC XV-M567 DVD Player
Turns on and only stay on a second...then shuts right back off and the stand by lights comes on
Is there a reset button or is it broken
2 Suggested Answers
silly girl
  • 513 Answers
SOURCE: JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Posted on Jan 24, 2006
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Reset button is broken and need to reset adapter
When you look the reset button, does it have a color?
When you try to press it using a paperclip, does it click or did it just came through?
Right way to reset devices:
1. Use the tip of a paper clip.
2. Press and hold the reset button for 30 seconds.
3. Lights on the device will flicker.
4. When the time is up, turn off device, wait for 10 seconds and turn it back on.
Oct 03, 2013 | Computers & Internet
Wpn824NA Not working
Hello.
If the test light on the router stays on after 20 seconds, even after turning off the router and back on it stays lit, it means the router has a problem.
What you can try to do is reset the router to factory settings:1. With the router powered on, hold down the reset button on the back of the router for 20 seconds until the test light on the fron panel turns on.2. Release the reset button and wait for the router to restart and become stable.
If the test light does not stay on anymore, the router should be ok, you need to set it up again though.
Hope this helps. Glad to be of service.
Nov 24, 2011 | NetGear Computers & Internet
How can I reset a Sony Wega tv without a remote control... I stand by button keeps on flashing and the tv wont stay on for more than 3 sec.
You can only reset the TV when you have the remote as it requires holding down the RESET button on the remote control, then pressing the POWER button on the TV front panel. The TV will turn itself off, then back on again. Then release the RESET button.
Regarding your problem with the TV not staying on for 3 seconds, you can try unplugging the unit for at least an hour to perform a hard reset of the microprocessor. If the unit still doesn't stay on, you need to check the power supply or the entire board for any blown or bad capacitor, shorted terminals due to accumulation of dirt, or broken solders. It may be a tedious task and requires an electronic prowess to do.
Kudos and thanks for using Fixya.
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Maintence light is blinkin when i start my car
Generally, the maintenance light should come on for a few seconds, then go off after the car has started. All of the dashboard warning lights do this so driver can tell they are operational. (Should see brake light, low oil pressure, airbag warning, etc. Any of the lowly "idiot" lights should come on.)
As a test, turn the key on, but not to start. All of the lights should flash on for a few seconds, sometimes in sequence, then go out. Now, sart the car, some lights may come on and back off. If none stay on after a few seconds of engine running, you are probably ok.
Sep 23, 2009 | 2000 Honda Accord
Acer Extensa 4420 WILL NOT turn on
How old is it? Sounds like your battery may be toast.
Jan 28, 2018 | Acer InviLink 802.11b (91.49C10.002)...
Tv won't stay on
i have seen this before and it may be the front power button being stuck and when your remote turns it on the stuck button turns it back off again. I have an older mitsubishi that will not boot up right sometimes and i have to unplug it and plug it back in fot it to come on. I used to pick up broken tv and fix the power buton and resell them
Mar 27, 2008 | Televison & Video
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
JVC XV-M567 DVD Player Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
