Question about Dewalt Factory-Reconditioned DeWalt DW432R 8 Amp 3-Inch by 21-Inch Belt Sander with Dust Canister
Motor runs but the drive drum that hold the sanding belt does not turn.
The motor runs and the belt pulleys are fine, but the drive drum for the sanding belt does not turn. I am unable to get the drum off of the sander to determine what is not working properly. I know the nuts are left hand, but they are recessed into the drum itself.
  • Anonymous Mar 25, 2014
    Conveyer belt drifts to right to wards pulley
    Novelist:
  • 99 Answers
Instead of removing the drum, remove the belt and the cover over the gearbox. The gearbox cover is normaly fixed in place by screws around the drive pulley. There may be a couple of screws under the pulley, if so they can be accessed via holes in the pulley wheel itself. Check for worn or stripped gears. These gears can be replaced if need be, but if this is the case make sure you remove and clean out all the grease first and replace that aswell as it may contain bits of teeth that have come off the faulty gear. As far as I know belt sander drive rollers can not be removed without removing the drive inside the gearbox first.
Posted on Nov 01, 2008
Wcvh62604fww starts fills and drains but does not agitate or spin. It does turn the drum in the beginning to test the load
These symptoms appear to be a problem with the drive system which includes the inverter that drives the drive motor and of course the drive belt. Verify first if you can hear the drive motor running and if yes, the drive belt has broke or slipped off the pulleys. Remove the screws securing the rear access panel and pull it outward from the middle to access and check the condition of the drive belt. Reinstall it if possible or replace it if necessary. Wrap it around the motor pulley then on one side of the drum pulley and turn the pulley in the direction in such a way that the belt will wrap the drum pulley.
Turn the drum pulley and the motor pulley with and without the drive belt if upon checking, the drive belt is still on. It will be known if there's restriction in either of the motor or the drum that prevents the machine from agitating or spinning. Try to start the machine with the drive belt off if no restriction is found which indicates that either the drive motor or the inverter is at fault.
Check the resistance of the motor windings (normally around 6 ohms across each of the 3 phases;otherwise, replace the motor) if the motor still doesn't run with the drive belt off. Check the continuity of the wire harness connecting the inverter and the drive motor if the winding resistances are good. Consider replacing the inverter if no problem is found with the drive motor and the wire harness.
You don't have to accept or reject this post in order to add information or post comments and follow-up questions should you need further help. But accepting a solution does not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 30, 2011 | GE WCVH6260F Front Load Washer
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
My amana ned7200tw electric dryer turns on but doesn't tumble/run... the pulley is ok checked that any other ideas
all there is is a belt that turns the drum,the belt goes on the motor pulley around the pulley and around the drum, check the motor pulley to see if it unattached from motor shaft or check the belt to see if it flipped over somehow,there is a smooth side and a ribbed side on the belt and you said the pulley is fine
Nov 07, 2009 | Amana NED7200TW Electric Dryer
How to attache drive belt to drive drum .belt will not reach.loosening bolts that hold motor on did not help.forced on but belt twisted on drum.
Remove rear cover of washer, and top cover also, tilt washer towards you, get someone to hold washer steady, fit belt round motor pulley,and slowly feed belt round drum pulley, watch your fingers, keep feeding belt round oulley, turning drum at same time, it will be tight, but persist, and belt will go on.
Please rate my solution.
Thanks.
Sep 28, 2009 | Hotpoint Aquarius WF220 Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Motor & pulley
It would take 6" pully w/ a 2.25" which would not fit on that machine, no room for the 6". Replace with the same RPM motor is the proper way, unless you simply want a slower speed sander, duh! You cannot change the motor rpm without a defenant power issue, if you change the rpm your sander will power out, sorry?
Mar 30, 2009 | Tools & Hardware - Others
My dryer will not start. It is not locked. I've turned it off and unplugged it for 30 minutes. All the buttons work fine, but the timer just flashes when I push the start button. Help!
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Whirlpool Dryers
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
  • Remove the belt.
Jun 15, 2008 | Magic Chef Dryers
Dewalt Factory-Reconditioned DeWalt DW432R 8 Amp 3-Inch by 21-Inch Belt Sander with Dust Canister Logo
407 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
xenophanes
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
