Question about KitchenAid KSBP25FKSS Side by Side Refrigerator
KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser on door not working. I heard that this might be a celenoid problem?
Any ideas?
Steve
  • ryandooms
    ryandooms Apr 17, 2012
    Had the same issue. But there is a fix if your handy with wires. Remove the lower cover plate below the doors (2 Screws). You will see black wire loom going into the bottom of the freezer door leading to under the freezer. Remove all tie down screws and ground screw. Cut away all wire ties. Unplug wire harness under freezer. Carefully **** the wire loom up and completely cut a way the wire loom and dispose of. You can now see which wires exactly need to be spliced from rubbing on the door. Solder and shrink tube all connections back together. Wrap all wire together with electrical tape. Provide new wire loom and install of wiring. Mount everything back but I would use one less wire mount to create more slack in the line to prevent future breakage. Should work just like new. I have had zero issues since using this fix. Good Luck and I hope this has helped you.
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Posted on Feb 02, 2009
This refrigerator has other design problems, which Kitchenaid refuses to address...Does your ice maker spill ice all over the inside of your freezer because of the gap at the back of the bin? Constantly hearing the clitter clatter of falling ice inside the freezer and having to pull everything out to remove all the pieces from the bottom of the freezer became such a nuisance my husband finally duct taped a piece a plastic to the bin to fill the gap. I won't buy another Kitchenaid anything because they wouldn't fix the problem.
Posted on Sep 26, 2009
  • 1,010 Answers
Yes it could be the solenoid, but before replace it make it sure, you have power at the solenoid, if not then your door switch or wire in the door is broken (at the bottom)
You can direct power the solenoid if you are familiar with electricity, if not then please DO NOT TOUCH IT.
Posted on Mar 06, 2013
Frigidaire refrigerator filter status light is red
That information is in the user manual that covers your model number. Below is the procedure for a Side by Side. To look for your manual click=> HERE
Press and hold the Water Filter button
on the Ice & Water Dispenser control
panel for three seconds. When the display
changes from "Red" to "Green," the status
has been reset.
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 17, 2014 | KitchenAid KSBP25FKSS Side by Side...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
I have what appears to be a water leak of some kind in the freezer section near the ice making part of the freezer. You can tell because the freezer is building up ICE all around the bottom of the ICE...
Check to be sure your ICE door chute is closed or closing properly! I have encountered many of these units that have had the flap break off the mounting tabs inside the dispenser opening. If the flap appears to be intact, I would next guess that your ice maker timing is allowing the ice maker to over fill and spill water into the ice bucket.
You can confirm this problem by looking at the ice maker and seeing if the ice cubes in it are filled right up to the center bar that drives the cubes out of the mold.
Let me know if you have any more questions!
Thanks, BOB
Aug 18, 2010 | KitchenAid KSBP25FKSS Side by Side...
Kitchenaid refrigerator water dispenser not working
you may need to replace the water inlet valve. it is a dual valve, one side for water and one side for ice. part #2304833. see the attached breakdown #10. perhaps this will help.
Oct 26, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water will dispense from the door but will not fill the icemaker
Me too, same issue. Just changed water filter prior to problem
Mar 17, 2009 | KitchenAid KSBP25FKSS Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water spurting from the water dispenser.
hold it in ad remove a a few quarts, you have air trapped in the line (normal after replacing water filter), large pitcher if possible
Feb 26, 2008 | KitchenAid KSBP25FKSS Side by Side...
Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Open Questions:
See all KitchenAid KSBP25FKSS Side by Side Refrigerator Questions
KitchenAid KSBP25FKSS Side by Side Refrigerator Logo
350 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
