Question about Sony Xplod XM-554ZR Car Audio Amplifier
No sound out of speakers
We hooked up the stereo now we have no sound out of speakers
  • 185 Answers
Ok so whats going on need aa litte more info than that
Posted on Oct 31, 2008
Hooked the stereo up and got power to but no sound coming out speakers but i try home speaker it work so what did i do wrong ?
if im understanding correctly what you wrote. you hooked up the headunit to the car and no sound from speakers, then you hooked up a single house speaker up and that speaker works fine. the Ohms on the car speakers might be too high, but most likely sounds like the wires to the speakers are bad.
Nov 21, 2013 | Cars & Trucks
2002 Pontiac sunfire front and rear left speakers not working ! Any idea what could be wrong ? I heard there is a factory amp do you know where that would be and if that could be the problem
factory amps are located on the stereo unit itself or in the trunk but only if the car was ordered with premium sound and the possibilities of that car being ordered with premium sound is unlikely. so at the harness in the back of the stereo find the speaker wires and hook up a 9 volt battery to the said speakers that dont work if they crackle then its in the stereo if not its the speakers or wires to speakers with battery hooked up and speakers dont crackle go to speaker and test with a vom and test for 9 volts dc
Jun 03, 2013 | Cars & Trucks
2001 gmc sierra rear pillar speaker setup. So I hooked up rear 4x6 speakers in the stock location. From the factory it didnt have rear speakers and when I hooked these up to the factory wires l dont have...
I would guess that GM didn't hook these wires up to the factory stereo, as the factory stereo may not have the front back fade feature. They put the wires in to save you time if you decide to put another stereo in. Look under the dash, you will probably see the other end there. I'm not sure about this. Just a guess, but my tractor trailer is set up that way, and I only have 2 speakers, but wires are run to all possible speaker sites. Good luck.
Jan 10, 2013 | Cars & Trucks
My sterio won't make no sound at all and I don't know why. I have a sub slash speaker hooked up to it and another big speaker hooked up to it and it still won't play no sound at all
Is it possible that you blew out the speakers? Or that they are not connected properly? Showing the front of the Stereo is not at all helpful to understanding your issue. Please give a view of the back of the Stereo so we can determine whether it is improper wiring, blown speaker, or faulty components.
Dec 08, 2012 | Audio Players & Recorders
No sound out of my speakers model 5269480
on your amp under the back seat their are 2 plugs the one on the left which is the smaller of the 2 there is a Tan wire w/Orange stripe on it hook the remote wire from stereo plug which will be blue w/white stripe to that wire so it will power-up your amp...Bottom line, no amp = no sound,unless you figure what wires are the speaker wires and hook directly to your stereo plug............Its an easy fix
Oct 13, 2012 | 1994 Jeep Grand Cherokee
How to hook up my speakers to asus cm series
Plug in the stereo jack from your speakers into the sound card audio out . Assuming you have a stereo jack on your speakers, other wise you might need to buy a stereo jack with cabling which you will need to hook up to your speakers,
Jan 05, 2011 | ASUS Essentio Desktop with Intel Pentium...
The sound is verey low
http://www.ripoffreport.com/Stereos/Theater-Research/theater-research-the-van-speak-73z89.htm
Apr 02, 2010 | Theater Research TR-2810 Main / Stereo...
Part of my speakers are just not working. Hooked up, and unhooked and re hooked, but not all speakers working. Right now just 2 of seven are working.
If u have a surround sound card that supports up to the amount of speakers u have (5.1 or 7.1) try change the speaker settings in control pannel as follows.
Start>control pannel>sound>
and see if u have the setting on stereo, if so change it to the 5.1 or 7.1 setting.
If u have software on the otherhand for your sound card you can configure the settings there to change from stereo to surround sound.
Hope this helped :)
Dec 14, 2009 | Logitech X-540 Computer Speakers
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Sony Xplod XM-554ZR Car Audio Amplifier Logo
80 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
