Question about Sony KV-32S26 32" TV
Panasonic model TX-29GF10X, went on stand by , and not Switching ON again, what is the majore cause?? or what does the TV need to restart again
    President:
  • 3,130 Answers
Your problem im afraid could be one of several things. Power supply problems,sweep supply,horizontal output transistor,standby power supply. The best thing for you to do , if your not a tech, take the set into a reair depot as these are solid state sets and have no user replaceable parts inside. Good Luck
Posted on Aug 28, 2006
Panasonic Quintrix TX-25MD3 4:3 CRT TV About 20 minutes after switching on, picture flicks to a very dark one with very vivid colours. Sometimes stays like that. Knocking on side of set sometimes brings...
Condensation on the circuits needs drying off by using the TV. There maybe also contact resistance preblems which needs vibration from the side of the TV to get it working right.
Nov 08, 2010 | Panasonic Televison & Video
Power just quit had a great picture
panasonic tv's suffered from frame chip problems causing them to be stuck in stand by .not an expensive part though...
Apr 25, 2009 | Panasonic CT-32SL14 32" TV
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
How to remove stand from panasonic tv model no tx-32 l m d 70
Place tv on its BACK,with the screw holes underneath.Remove the four screws,remove stand,and turn tv over to rest on the sceen (on top of a towel)or some other cloth so as not to damage the screen,and replace screws.The reason for placing the tv on its back when taking out the screws,is that,unless you have a magnetic screwdriver when removing the screws the are difficult to remove as they are deeply recessed.
Apr 09, 2009 | Emerson RP6248 AM/FM/TV Radio
How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Jan 31, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Problem with panasonic tv
It is usually caused by problems from lead solder that sometimes does not connect, so there are some points of the components that are not connected with lead solder to the circuit. if it appears vertical line means from the IC (integrated circuit ) Vertical, you can solder all the points in the IC ( Integrated circuit ).
Sep 07, 2008 | Panasonic TX-32LX1F 32 in. LCD TV
Panasonic tx-29gf10x image not filling screen
Hi there, I have the same model, and I had a simular problem , except my picture shrunk from each side of the screen into concave arc, if you know what I mean. I thought it might be a faulty horozontal output transistor, so I replaced that but did not fix it.
Eventually the picture quality dropped namely it became out of focus and i couldnt refocus it. Then it stopped all together and I heard a ticking sound, which I found was
coming from the line output transformer. A Tech friend told me it was probably a cracked or burnt out HV Capacitor, so checked them all and ofcourse they were all o.k.
So I have come to the conclusion that the Line Output Transformer is faulty, I hope I
am right as they are not cheap.
I think I have the answer to your problem which is a very simple one:
Adjust the "vertical picture height," and it will bring the picture down and fill the bottom of the screen. To do this adjust the VERTICAL CENTER SWITCH by pushing it forward towards the tube , this switch is on Board
TNP 107985 which is located right next to the AV inputs on the back of the TV, the switch is a round white component with a lever on it, and is located on the top of the board, push it to the max forward position, this should help, but might not fix it enough
depending on how much space u have at the bottom. There are no other vertical height adjustments on this Model so it would have to be a faulty component, like a HV
capacitor or burnt out resistor, or not enough HT drive voltage, which suggests dare I
say it--- Line output Transformer, could be wrong though.
Anyway good luck with your problem, hope what I suggested helps.
Dec 13, 2007 | Televison & Video
Tv is on stand by but won't 'fire up'
I don't know the age of your set but I've found some Panasonics with a loose connection on the heat sink (an aluminum plate standing vertically on the circuit board) of the regulator IC (chip). The IC gets its ground through the heatsink. If the ground is open the power supply puts out too much voltage and causes the set to go into shut down. I've found this problem several times. Stargazer
Jan 22, 2007 | Panasonic TX-28DK2 TV
Sony KV-32S26 32" TV Logo
183 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
