Question about Necchi 3101 Mechanical Sewing Machine
Very old Necchi sewing machine - sews in place
(I can provide the exact model later, as I'm not home right now). The motor starts, the needle works, but it doesn't move forward (the material does not start moving forward) It sews in place. What could it be? Is it worth fixing? Apparently it is hard to find service for Necchi machines (i'm in Montreal, Canada). Thanks for your help.
    Problem Solver:
  • 6 Answers
Sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Posted on Jun 24, 2009
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
textile
  • 10 Answers
SOURCE: Necchi machine
Bu Mira was made in Italy between 1952-1956 it was the machine where the introduced the Wonder Wheel to make decorative stitches, olive green in color . There are some people who collect them but like all antiques the rearer the are and the better origonal condition the are in the more the are worth.
Posted on Aug 02, 2008
  • 37 Answers
SOURCE: tread keeps coming out of the needle.
Make sure you sink the needle into the fabric before starting to sew. If that isn't it...remove the thread and rethread the machine. Make sure the thread isn't wrapped around the spool holder.
Posted on Apr 16, 2009
Mimito7
  • 128 Answers
SOURCE: Necchi Heavy Duty Sewing machine model 3205FA,
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Posted on Apr 22, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
I have a Necchi model 537FA. When u step on petal, it won't move. Does this machine have 2 BELTS? I only see one. I have oiled before running.
If you don't have any movement or hear the machine attempting to sew, you may have a burnt out pedal.
You should hear a slight hum when pressing on the pedal. If you don't hear a hum, the pedal is probably dead.
These can usually be ordered from the merchant who sold you the machine.
Apr 19, 2016 | Necchi Sewing Machines
Necchi needle bar screw
it would have been helpful if you had provided the model number of the Neechi sewing machine.
But if you go to this website you should be able to locate the correct part for needle bar clamp and screw.
Necchi Sewing Machine Parts
Aug 05, 2014 | Necchi Sewing Machines
I need a Necchi sewing machine manual for model 522FB
go to the website of allynint.com & contact them about a manual
I have 2 necchi sewing machine & use Schmetz universal needles
90/14
Mar 03, 2012 | Necchi Sewing Machines
The needle did not whant to go in right How to replace the needle on the machine model no. 4575 necchi
make sure the sewing machine is turned off first
the flat side of the shaft of the needle goes toward the back of the machine
insert the needle as far up as it will go
Sep 21, 2010 | Necchi 4575 Mechanical Sewing Machine
Where to put the oil for a Necchi Lydia 3 sewing machine
Beldia 1306 - did you ever solve your sewing m/c problem. I have just resurrected my old Necchi and have the same problem, power but very sluggish operation of the needle, could be oil that is needed. Can you help?
May 16, 2010 | Necchi Sewing Machines
i repair a lot of sewing machines as a hobby .. the necchi is one of the better ones .. they are easy to use and work well .. i almost always dontate the repaired machines to places like "womens shelter" .. "home for troubled girls" or just give them to someone that has nothing or cant afford new machines ... it sometimes makes a difference in their life if someone helps them get started .. modern machines vary from really cheap junkers that somehow work to really expensive machines that do everything but are completely out of reach for many.. the old necchis are better than many new machines but no one knows that .. so typically they sell for only $20 to $50 ... but if you donate a working machine to someone it can help, then its worth it weight in gold ..
Jul 24, 2009 | Necchi Sewing Machines
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Necchi 3101 Mechanical Sewing Machine Logo
448 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
