Question about Welding Tools
Butters got a butters merlyn 275 when i press trigger solinoid stays on making the torch live and gas escape after welding even if i disconnect torch soliniod still stays in sometimes it releases on it own
    Genius:
  • 1,212 Answers
Based on your description there should be 2 contactors. One is the contactor that controls power to the welder primary winding, this one should be quite large compared to the other one, the other controls the 24 volt (most common) supply to the wire feed speed control board and gas solenoid. If you do have 2 of these contactors, the 24 volt contactor may supply the control current to the larger contactor..
If blowing out the cabinet has not helped, and at this point it is not likely, the 24 volt contactor should be replaced. If a sealed one is available I would upgrade to that style. The ratings should be embossed on the contactor somewhere, otherwise your control voltage should be 24 volts, use a meter just make sure you are in that range, US, UK and Euro standard share some common specs. You may have a 2 pole or 3 pole type- it depends if the gas solenoid is powered off the same pole as the motor control board, or if it is powered by it's own pole. These would be the "N/O" contacts, and all would have current supplied by the 24 volt supply/control supply. The larger contact coil winding would be on it's own pole. Contacts should be rated at 15 Amps minimum
Replacing both contactors at the same time if so equipped is a cost effective bit of maintanence.
If you have only the single 24 volt contactor, the tip will be live at all times and it will only be the gas and the wire feed control board that would be switched by the contactor.
Again, based on description, I would replace the 24 volt contactor. Contacts should be rated at 15 Amps minimum
I would also just check the gas solenoid with a jumper wire to make sure it opened and closed as it should.
Posted on Feb 21, 2012
3 Suggested Answers
  • 81 Answers
SOURCE: I have a fault on a mig welding machine. when the
it sounds to me like the motor is binding and shutting off on overload and then back on, did someone remove the drive rolls and install them without the spacer so there is drag on them now, I would remove all the drive rolls and other hardware on each shaft and then activate the run switch, if it runs smooth then the problem is binding in the drive roll assembly if it still hesitates then I would say the relay or motor are questionable, easiest way to check out the run switch is to remove the cable going to the remote and connecting a wire between the wires going to the switch and seeing if the motor runs ok if not then the switch would be bad. Hope This Helps Don
Posted on Dec 07, 2009
  • 223 Answers
SOURCE: When I plug in my
Does it just do it once for a short time each time the machine is plugged in? If so, don't worry about it.
lp
Posted on Dec 24, 2010
If I am using a 150A High frequency TIG welding machine, would you recommend a torch with gas control valve or not
You should control the normal gas flow at the bottle with a flow meter. Your welder may have additional settings such as 'post gas' and 'pre gas' to start the flow before you press the button or keep it going for a short time after you release it.
Sep 07, 2011 | V, Inc. Weldcraft Wp17v Weld Like A Pro...
I have a Victor R1600 Cutting Torch that the trigger handle malfunctions after a couple weeks of use. The company replaced the first one, but will not replace another, only credit! The problem with the...
Hi:
That's and easy fix and you can do it yourself, call your local welding store like praxair www.praxairdirect.com and give them the brand and model of the torch and they will SHIP direct to you the right part. Check the link here.
Aug 22, 2011 | Victor ST900FC Straight Cutting Torch...
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Sir, we are using machine mounted MIG welding torches.Before these torches are working properly, now we got problem i.e, nozzle became red hot, cos of this we had stopped our production. pls suggest me.The...
Ensure that you are using the correct contact tip in the welding gun, if the tip is too short; the cup will fill with splatter and submit excess heat to the cup.
Also, make sure if you are using a name brand gun 'miller, lincoln etc' to use THEIR contact tips, the miller guns use a special tip 'the threads on the tip are mashed into the gun ensuring maximum contact for high amperage welding' if the wrong tip is used, it will overheat and jam the wire.
Another thing to remember is to check the amperage rating on the actual gun itself; you may have a 150 amp maximum gun on a 300 amp welding unit.
Good luck
Feb 09, 2011 | Lenox 21172 Welding Torch
I just bought a torch. and i was just wondering how to use it. i was just wondering how much oxigen to gas i use
depends of the torch you are using, if you have a single ought or 0 then run the oxygen at about 17 pounds and the gas at 7 pounds, this should give you a good clean cut. Remember to turn on the gas all the way, since gauges run slightly off you may have to increase one or the other, on the handle and barrel assembly you can adjust the gas first light the gas then turn on the oxygen get a good blue flame all even on the tips then turn the oxygen knob all they way on then when cutting be sure to heat the metal forward and move forward at a 17 degree angle, when you hit the cutting lever after the metal turns molten hit the oxygen lever move evenly and slowly if you need help with welding with it let me know and I CAN GIVE YOU SOME TIPS ON GAS WELDING.
Nov 21, 2009 | Northern Tool Dual Turbo Propane Torch Kit
1995 nissan maxima doesnt start when cold, just clicks, and after trying for 5 to 10 minutes it finally starts... Please help me out...
it is one of two things.
  • the starter is either worn and brushes not making contact or an engine oil leak onto the starter. thus keeping the brushes from making contact you can check this by banging on the starter while someone trys turning the ignition back and forth to start.(making the click click click)
  • ignition switch is weak, not providing enough voltage from the to kick the soliniod all the way to start the starter
The way to check that is to hot wire the starter soliniod little wire, to battery voltage. (the big cable on the solinoid)
If it turns over good, then you can either replace the ignition switch or install a relay someware near the starter to supply it with propper current to kick the solinoid all the way to engage the motor.
The relay acts as a remote starter switch that feeds more direct power to the starter solinoid.Now the only thing the ignition switch is responsible for, is trigger the relay.
Oct 31, 2009 | 1997 Nissan Maxima
Welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
Dec 22, 2008 | Miller Electric Manufacturing Electric...
Welding Tools Logo
149 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
