Question about Canon EOS 40D Digital Camera
Canon EOS 40D - err. 99 while taking photos
I have a problem with my camera - Canon EOS 40D. The camera is relatively new, I bought it in May. Very often, when I take a photo, the LCD displays a massage: " Error 99. Shooting is not possible. Turn the power switch to and again or re-install the battery". Then I follow the instructions, but the problem tends to repeat. What is interesting, my Canon sometimes takes photos and in such a case, it seems everything is all right.
I use a lens EF 17 - 40mm L series. I have changed the lense and tried taking photos with other lense, which I borrowed from a friend, but it didn't solvbe the problem.
I don't know what to do. In my city there is no authorized Canon service.
I heard from one photographer that it might be a problem with the Software installed on my camera. Where can I download software for the camera and how can i upgrade it i my device?
Thank you for your help
  • 1 more comment
  • Anonymous Jan 06, 2009
    I had same problem. I sent it to Canon (also purchased mine in May). Canon stated it was the mirror and they had to replace it. Waiting for it to be returned. Send to Canon while it is still under the year warranty.
  • kayalvin Jan 23, 2009
    Err 99 Shooting is not
    > install the battery.)
  • Anonymous Jan 25, 2009
    Same here, mirror Assy. changed by canon.
    Problem Solver:
  • 12 Answers
Update your firmware to 1.0.3 , this will fix your problem
http://web.canon.jp/imaging/eosd/firm-e/eos50d/firmware.html
Posted on Oct 29, 2008
Error code 99 on a 40D?
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Apr 17, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you...
Welcome to Fixya
Thanks!
Mar 27, 2011 | Canon EOS 40D Digital SLR Camera Digital...
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Thanks
Jan 30, 2011 | Canon EOS 40D Digital Camera
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
May 14, 2010 | Canon EOS 40D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
Jan 07, 2009 | Canon EOS 40D Digital Camera
Err99 40d canon body only
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
226 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
