Question about HP Photosmart 3210 All-In-One InkJet Printer
Fatal error when trying to open software
I just put a camera card into my photosmart all in one 7180C in order to copy photos over to my computer and as soon as I clicked on Icon, this error came up and said it will terminate immediately. The error number is CLR 8007000b.
Any suggestions what is going on, or if I should call our IT people.
Crisis when a prog sound like it folder !
bad image error..
soln: rename folder / program if possible..
other one is to reinstall whole .net suite & the rest
Posted on Feb 02, 2009
Hp photosmart e317 digital camera downloads for windows 7 operating systems
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program, such as Picasa.
Feb 19, 2012 | HP Photosmart E317 Digital Camera
I want to upload photos from my Panasonic Lumix camera, but PhotoFunStudio 6.0 gives a fatal error: CLR 80004005 every time and won't open. It worked the first two months and now the program won't...
Your best bet may be a card reader.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Oct 31, 2011 | Panasonic Lumix DMC-FH25 / DMC-FS35...
I have a HP M525 camera, Seerial No. CNGBUQ30Z4. Recently, when trying to transfer some up-loaded picturs (from the camera to the computer)the screen went blank. When I tried to restart the process by...
The possible solution's are
1 . First uninstall the photosmart software from the system and reinstall the software once again . Install in C: drive and then connect usb and transfer photos this will work . If this doesn't work then try in another usb port of the computer and transfer photo's .
2. Photo's will be in memory card ,better get memory card reader and take out the memory card from the camera and insert it into the card reader . Now connect card reader to computer and transfer photo's .
Hope this helps .
Mar 23, 2010 | Cameras
My HP Photosmart M407 digital camera won't upload photos. I've uninstalled and reinstalled the Image Zone software several times. It comes up and freezes.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Nov 06, 2009 | HP Photosmart M407 Digital Camera
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
I don't have a manual - I am trying to download pictures from a HP Photosmart M415 camera onto my laptop. I have the cords to do it with - don't know the program or how to do it.
To download the manual for your camera, please click the below mentioned link:
HP Photosmart M415 manual
To download the software(program) for your camera, please visit this link:
HP photosmart full software and driver (XP and Vista)
For instructions on how to install and run, please visit the link below:
Installation instruction
Apr 15, 2009 | HP Photosmart M415 Digital Camera
Digital camera that will no longer connect to the computer.
I don't know about your "picasa" software, and the importing procedure, but you could simply plug your card into the SD slot on your PC, and it will show up as a 'removable drive' located in "my Computer". You can open it and simply copy/paste the photos directly to any folder you wish. In other words, you don't need any specific software to import photos, and to me it's a much simpler process.
If you don't have a card reader on your PC, you can buy a USB to SD adapter to plug into your USB port for $15 +/-
Mar 12, 2009 | HP Photosmart M415 Digital Camera
Everytime turning on computer application error comes up hpgthb08
Dec 13, 2008 | HP Photosmart R607 Digital Camera
HP Photosmart M627 Digital Camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 20, 2008 | HP PhotoSmart M627 Digital Camera
Won't download
This seems like a card or software error.
If you are using the camera software[from the disc] to upload the images- remove the software[Start/ControlPanel/add/delete software]
Windows does not need software to perform this task.
If that fails
Invest in a USB card reader and always use that to down load images.
Oct 26, 2007 | HP Photosmart E327 Digital Camera
HP Photosmart 3210 All-In-One InkJet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
