Question about Philips Norelco 8240XL Electric Shaver
How to put back together after cleaning
While cleaning I dropped all the parts out and I am not sure now to put back in need a diagram or something
I need a diagram on how to put the interior back together, since I dismantled it completely.
I suggest to search online for parts info on interior.Sometimes they show parts exploded
Dec 10, 2013 | 1988 Acura Legend
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
The bobbin case on my 2273 (the whole thing) fell out and I need a diagram on how to put it back.
If this is the Singer 2273, then did the hook cover and hook come out? See the pictures on page 2 of the oiling diagram here: http://www.singerco.com/uploads/download/1235_oiling-2263.pdf .
If you need to replace these two parts, turn the handwheel until the hook race is in the left position. Then put in the hook (thickest part down) and then the hook cover (the side with the notch towards the machine and facing up). Rotate the hook retaining arms back towards the center of the hook cover to lock it in place. Now you should be able to put the bobbin case back in. Since this is a part that needs to be oiled regularly, wipe it out with a soft cloth and put 1-2 drops of sewing machine oil at point 6 (just to the right of center) in the shuttle before you replace the hook.
If additional parts have come out or the retaining arms are damaged, try finding the parts diagram for your model at the Singer site: http://www.singerco.com/support/replacement-parts-chart . THen see if a Singer dealer has replacements available.
I hope this helps.
Nov 18, 2011 | Sewing Machines
I would like to take my homelite vac attack apart and clean it and change oil and change spark plug and clean the gas line and other parts and put it back together. So I need a list of how you clean the...
go to www.ereplacmentparts.com for a diagram. just pay attention when taking apart. its not hard. even lable parts if you need to. an air compressor will be useful in cleaning. and brake cleaner does good on oily parts.drys quick and leaves no residue.
Jul 09, 2011 | Homelite Leaf Vac Attack
Put on a new head with studs in the rock arm , the nut that screws on the stud is backing off when i start the engine what should i do did i miss something or put something back wrong need help
just put some high-temp red loc-tite thread locking glue on the thread before you put it back to gether, just be sure to clean off the surface of what you want it on and you cna put oil on the parts you do not want to stick together.
Jul 01, 2011 | GMC Jimmy Cars & Trucks
I need rebiuld my carburaitor is all ready clean (I cleaned in carb.& parts cleaner) blowt-aut whit 90 psi I have new repear kid only Ineed the diagram or manual to putin back togader
THE CARBURETOR KIT HAS A DIAGRAM ON HOW TO ADJUST FLOATS AND PUT CARBURETOR BACK TOGETHER.EVERY CARBURETOR I REBUILT HAD A DIAGRAM TO REASSEMBLE PUT CARBURETOR BACK TOGETHER.
Apr 30, 2011 | Mazda B2200 Cars & Trucks
Troy Bilt pressure washer model 020209 has very low spraying pressure. How do I repair the pump?
you are going to need a pump seal kit or they may call it a rebuild kit but this sort of thing happens often and you should not have any trouble getting the parts you need with the kit should come a exploded view diagram but request one just to make sure be careful when putting it back together if gyou damage any of the brass or neoprene parts you will be putting it together for nothing lay out your parts on a clean towel keep all dirt and grime away and clean your pump housing really good before you put the new parts in and i mean clean enough to eat off of if you do all of these things your rebuild will probably last longer the the original good luck and get back with me if you need help with the rebuild
Jun 29, 2009 | Garden
I DROPPED MY KODAK CAMERA WHILE THE CAMERA WAS ON
If you pressed it too hard in, you most likely damged some other parts in addition to the damage caused by dropping it. You need to take out the lense, inspect all the moving parts. Look for broken or bented part. The opened lense should mover up and down easily. Make sure all parts are clean and put the lense back on. Good luck!!!!!!!
Jun 09, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Philips Norelco 8240XL Electric Shaver Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
