Question about Whirlpool Washing Machines
My washer starts up and the water starts to fill up but the water dont say in the washer
Washer will fill but not start to wash.
the problem is dont fill with water first bt wat u do is jst load the clothes first den u nw start filling with water wen it get to the water level it will start working or if such repeats itself call ur technician
Jun 28, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Water level dont stop I bougth a new part and still have the same problem the water dont stop.
put the washer on cold,start to fill washer, turn washer off if water still keeps filling you have a bad water valve,do the same test on hot,if both turn off when you push stop then check the water level hose from the water level switch to the tub,if both ends are secure then replace the water level switch-mike
Feb 18, 2010 | Kenmore 22422 Top Load Washer
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer overfilling tub and not shutting off
did it start agaitating? if yes then its your water valve.[where the fill hoses attach to washer from house] if no then it has to do with water level switch.in whirlpool/kenmore washers its very common for the water presure tube to come off of the water level switch.up in the timer console area.other brands dont have that happen as much.some times a mouse has chewed in that presure tube .see what you can do with that.check back with us if needing more help. God bless ,tom
Jan 06, 2009 | Washing Machines
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water Trickles in When Filling
check the sreens in the hot and cold water valves on the machine make sure there not plugged with rust
Mar 06, 2008 | Roper RAS8445KQ Top Load Washer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
