Question about Radio Communications
Plantronics C120-M headset, I plug it in to the usb port and does not work? Any help?
  • Captain Skittle May 13, 2013
    i have same problem have u fixed it if u did please tell me how
5 Suggested Answers
SOURCE: I get no sound and my my microphone doesnt work.
1. go to control panel
2. choose "sounds and audio devices"
3. choose the "audio" tab
4. there are "default device" for "sound playback" and "sound recording", change both to logitech usb headset"
you then effectively enable the headset and disable the speakers. and the sound will remain on the headset after unplug and replug.
Posted on Oct 30, 2007
SOURCE: Plantronics Bluetooth Headset P590
my headset doest charge too. i tried the desktop stand...and the AC adaptor....but no power comming through. i cant say that my power isnt working coz when i tried the universal adaptor...that was charging fine. i have got a P590. PLZ HELP.....thankxxxxxxx
Posted on Jun 17, 2008
onyeobike
  • 70 Answers
SOURCE: Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
Posted on May 21, 2009
vanherringto
  • 1738 Answers
SOURCE: Can one get the plantronics audio 995 USB headset
I believe it should work...
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Posted on Feb 07, 2010
My Plantronics C420-M is not recognized
How To Fix Error Code 43 Windows has stopped this device because it has...
If Windows Device Manager is giving a code 43, this means the hardware is reporting something wrong when trying to connect. I'd do the following (and also check the attatched link for reference ;-) )
  • Unplugging the headset, restarting the computer, then plugging the headset back in.
  • Make sure the USB connector on your headset (and the USB port you're putting it in) is undamaged, and not dirty.
  • Try connecting the headset to another USB port, and another computer to see if you're able to reproduce the issue there (if not- it may just be the USB port(s) on your computer that you're plugging the headset into that's failing.
If all else fails, it may be time to purchase a new headset ;-)
Jan 22, 2014 | Plantronics Blackwire C420-M Headset
Compatilble with macbook?
If you just plug the headset into your computer's USB port you should be good to go. With these headsets, there's no software to install, no configuration, etc. So it should be compatible with macbook
Jul 19, 2012 | Plantronics .Audio 355 Multimedia Headset
I need to know what splitter I can use for a Plantronics Blackwire C220 headset. I need to be able to plug in 2 headsets and use one to listen only and one to talk and listen. Please tell me what splitter...
There is not a USB splitter for computer headsets like the Plantronics BlackWire C220, you would have to go to a commercial grade headset to have that function. You can use any of the Plantronics "H-series" headsets with the Plantronics Y-training cable (model 27019-03), along with a USB adapter like the Plantronics DA40 or DA45 for training purposes.
Good luck from Headsets Direct!
Sep 14, 2011 | Plantronics Blackwire C220 Headset
When I plug in my Audio 625 Plantronics to my usb port it shows an error - Device not recognized, please help..
If you are using a Mac computer your Plantronics .Audio headset will not work The microphone plug on the .Audio analog headsets is not compatible with a Mac. It will physically fit into the Mic input jack on a Mac; however, it will not function. Basically, the digital sound card does not recognize the analog signal coming in from the headset.
Apr 16, 2011 | Plantronics Audio 625 Headset
Hi, At the office we have a Mitel IP phone we have just bought a headset model JAC0021201- B. We cant get it to work. Please can you advise how we set this up. Regards Trevor
I'm not finding manufacturer detail on this headset, only sales via Amazon, and it's dicey info at that.
So,I'm not certain this headset is compatible.  The only Mitel approved headsets are the Plantronics Polaris models.  These headsets fit into the headset port.  Such headsets require a headset button to be programmed and enabled on the phone to work.  When the phone rings, you will have to press the ringing button, to hang up, you will have to press the cancel button.
Other headset models may work, but require them to be plugged into the handset port and the existing handset will have to be plugged into it's unit.  Such units will require lifting the handset to answer the call and hang it up when completed.  Some such units have an optional lift kit.
I personally use a Plantronics Polaris "in the ear" model.  Plantronics web site has a config guide that will help you select a headset.
http://www.plantronics.com/us/configurator/default.jsp?use=Deskphone
good luck,
Mark
Mar 16, 2011 | Mitel 5220 IP Phone
I want to hook the plantronics 367 headset to my ps3 for chat and gaming purposes but the ps3 only has USB ports while the headset only has 3.5 mm jacks. one Jack is the audio and the other is the...
I'm sorry but per Plantronics the Gamecom 367 headset is not compatible with the ps3. The Gamecom 777 will work with the ps3.
Here is a link for more information on the Gamecom 777.
Feb 13, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
My Headset does´nt have dialtone, I was connecting to cisco phone 7941, 7970, 7911, and nothing, not work.
You can use a Plantronics S11 headset with a Cisco phone, however it is not the best compatible solution. To use an S11 with a Cisco phone, you have to make sure that you are plugging it into the handset receiver jack and not the headset jack. You will need to lift the handset receiver, set it off to the side, and then hang it up after each call. If you want a more compatible solution that you can plug into the actual headset jack and just press the headset button on the telephone to answer and hang up, then you would need one of the Plantronics "H-series headsets" with the Plantronics Cisco direct connect cable ( model 26716-01 ).
Plantronics 26716-01 cable
Plantronics H Series Headsets
Aug 12, 2010 | Plantronics S11 Headset
I just purchased a micro phone for skype, where do I plug it into my computer at.
is it usb? If so just use a normal USB port on PC and then go through the Skype set up routine.
Jan 27, 2009 | Plantronics CS60 Professional Headset
Radio Communications Logo
629 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
