Question about Toshiba Qosmio G35-AV600 Notebook
Toshiba G35-A600: How to replace the wifi card?
Both the Wi-fi and bluetooth went out at the same time. Is there something that both are connected to that might cause this problem? Where is the wifi located on the computer?
  • Margaret Feb 22, 2012
    My Toshiba is Qosmio G35-A600 not a Portege. Do you have a link to the Qosmio model? That would be really helpful to me.
    This is the first issue I have ever submitted. I know next time that I need to add things I have already done to expedite matters and get more stream lined responses. Thanks everyone!
    New Friend:
  • 117 Answers
Please follow this link for the schematics:
Click here
Gadget
Posted on Feb 21, 2012
IrishDruid
  • 2712 Answers
SOURCE: adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
Posted on May 04, 2008
Silverblade
  • 173 Answers
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Posted on Nov 05, 2008
citirulez
  • 44 Answers
SOURCE: Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
SOURCE: my toshiba satellite x205-s9349 cannot connect to internet
Despite wireless connections being susceptible to EMI, bluetooth signals do not tend cause the kind of interference that would prevent you from picking up a wifi signal. You say the wifi switch is on, but the bulb is red. (It is supposed to be red, that indicates its powered on). The things to check are to see if you are detecting the wireless signal, are you inputting the proper protocols for any known established wireless Security (WEP/WPA). Are you using a wired connection to get on the internet or another computer/location?
Posted on Jun 26, 2009
SOURCE: I have a problem witch wi-fi. my wi-fi can'not
here is the download link for your Wi-Fi driver
For Windows Vista :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_realtek_28824A.exe
For Windows 7 :
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_wifi_atheros_TC00190600E.exe
Download and install the driver according to your operating system.
Your Wi-Fi will work fine now.
That's it.
Posted on Jan 24, 2010
Bluetooth will not stay connected to cell phone when wi-fi is in use
If this only happens at home, you can probably enter the wifi settings and change the channel it uses to connect. If it happens any time you're near a wifi connection, you'd have to change the channel setting within the Bluetooth device if that's even possible.
Mar 08, 2014 | BluetoothTronics.com Plantronics Marque 2...
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
Lenovo 3000 N100 (0768-A53) 15.4
if you have wifi then set your printer to wifi enable and connect with your computer, no need of bluetooth
May 21, 2012 | Computers & Internet
I tried to connect player to my wi-fi with the adapter that came with my wi-fi package. Player does not recognize it as being connected. Do I have to have a specific wi-fi adapter?
Hello
You must have a wifi adapter ready LCD tv,if you have got this and the player still does not recognize the adapter then i guess your adapter is faulty and you should have it replaced..
Your player uses WiFi adapter WLM-10UB1. Which is the same one that can be purchased on the TOSHIBA website http://toshibadirect.com . This adapter works in several of the Toshiba models.
The optional Toshiba WLM-10UB1 Wi-Fi adapter retail price is $49.99, mail order around $41. 2.
Apr 12, 2011 | Toshiba BDX2000 Blu-Ray Player
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
My Iphone wifi button is grey out
Resolution First, sync your iPhone or iPod touch to iTunes to backup your user information, Contacts, Calendar, and other data. Then try the following steps in order.
One On the device, tap Settings > General > Reset > Reset Network Settings. Check to see if the device now displays the Wi-Fi address or Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and a Bluetooh address, then you're done with these steps and you can resync your settings and your media using iTunes.
If there's still no Wi-Fi address or Bluetooth address, then continue to step two.
Two On the device, tap Settings > General > Reset > Erase All Content and Settings. Check to see if the device now displays the Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth). If there is a Wi-Fi address and Bluetooth address, then you're done with these steps and can resync your settings and your media using iTunes.
If there's still no Wi-Fi dddress or Bluetooth address, then continue to step three.
Three
  1. Restore the iPhone or iPod touch software (this erases all data on the device) using iTunes (see article 305744 for additional assistance).
  2. After the restore is complete, sync your previous settings (mail settings, text messages, notes, call history, contact favorites, and so on).
  3. Now see if your device shows a Wi-Fi address and Bluetooth address (tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth).
If there is a Wi-Fi address and Bluetooth address, then you're done with these steps. If there is no Wi-Fi address or Bluetooth address, then continue to step four.
Four If there is no Wi-Fi address or Bluetooth address listed after doing the above steps, then your iPhone or iPod touch may need to be repaired. See the iPhone Service FAQ or iPod Service FAQ for additional service information.
Nov 08, 2009 | Apple Computers & Internet
Toshiba portege A600 notebook. wireless
unless you have a wireless router in your home; the msg "windows cannot find any wireless networks"
means any network in your area is too far away, or has a signal so weak your laptop is not picking it up as a viable source.
visit . www.filehippo.com and DL a file called Ccleaner. Run this program - it will clean all your internet caches and junk files, then run the registry cleaner. Reboot.
This can keep you from connecting.
Also try moving to different areas in your home and refreshing your wireless search.
if you are worried your wireless card may not be working properly, take it to a place like mcdonalds, or anywhere that has free wi-fi offered. if you still can not pick up a signal there you have narrowed it down to your wireless adapter.
you can also try this little program. Easy Wi-fi radar found here
Sep 17, 2009 | Toshiba PortegeA600-S2201 Notebook
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
Wi-Fi on an e350
I am not sure but I think that e350 do not support Wi-Fi connection. As far as I know it works with Bluetooth SD card.
Sep 11, 2005 | Toshiba e350 Pocket PC
Toshiba Qosmio G35-AV600 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
