Question about Jl Audio 1000/1 Car Audio Amplifier
Low ohm light flashes but green light also on
    Genius:
  • 1,212 Answers
It might be an issue with the crossover network. A high pass cap may be shorting intermittently. You may also have a loose wire abraiding somewhere.
Posted on Feb 21, 2012
  • contreras_at
    contreras_at Sep 05, 2013
    thank you i open one of the high pass cap and there it was it was two 63v3300fu were bad...
Sx30is flash off position. I would like to take a picture in low light without a flash. The camera emits a green light as a warning that the flash is off. I would like to not have either the flash or...
The reason the camera has the green light is not to warn that the flash is off. The green light is used to help the camera auto-focus in low light situations. If you disable auto-focus and use manual focus the green light should not flash when taking the picture. Let me know if that helps!
Jul 10, 2011 | Canon PowerShot SX30 IS Digital Camera
My 79 honda500 want fire i know the coils are and plugs and plug wires are good what else could it be and it hasnt jumptime either
have you checked the spark plug caps, if they read above or below 5000 ohms replace them. If they are good then the news is bad. You could have a bad cdi box but more likely with this model , you have bad pulsar pick ups, which unfortunately are part of the alternator assembly. These can be checked without removing the engine by taking readings from the plug going to the cdi box. ac generator disconnect the stator wires at their connections. X10omega
white-blue 77-95 ohms
green-white 387-473 ohms
orange-green 95-116 ohms
light blue-green 95-116 ohms
orange/red-green 81-99 ohms
light blue/red-green 81-99 ohms
advance pulsar
orange/white-green 185-225 ohms
light blue/white-green 185-225 ohms
Jun 03, 2010 | 1979 Honda CX 500 A
I have a green light on and the low ohms light on whats the problem?
no problem i see. Should be the power light, and the lower the ohms the better it is.
May 11, 2010 | Jl Audio 1000/1V2 Car Amp
Samsung Sync Master 914 has no picture. When power supply is only in, green light flashes slowly. When both power and vga are in, green light flashes more quickly. I hear a faint clicking sound coming...
I would check the caps with ohm meter. Make sure they all show increasing resistance. Caps can be bad without looking bad. Check output voltage on the power board, should be around 12V. If all that checks out then I'd look next at the backlight bulb. I'v repaired many monitors and the problem was almost always overheated caps on the power board. Post back and let me know.
Dec 03, 2009 | Computers & Internet
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
No drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Mar 12, 2009 | Electric Strider Midi 4 Wheel Mobility...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Flashing green light
i loose vga video controller
Nov 16, 2008 | Dell OptiPlex GX260 PC Desktop
Check engine light
one possible cause: many cars use the engine coolant temperature sensor to control idle speed and to shut down a dangerously overheated engine. if this sensor is sending a false signal, the controller will not know that and it will continue to listen to it. your task is to try and see if this signal is true or false. do this by measuring (USING A HAND-HELD MULTIMETER SET TO LOW OHMS RESISTANCE TEST) the resistance change across this sensor identified by a blue/white or yellow/red wire at one connector and a brown/green wire at the other connector. the sensor is located near the thermostat on the hot side of the coolant outlet from engine. if you find no change in ohms or find infinity ohms or always zero ohms, change the sensor and the light may fix itslef over time.
May 15, 2008 | 1998 Volkswagen Jetta
Jl Audio 1000/1 Car Audio Amplifier Logo
78 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
