Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Will my rockford fosgate p5002 support 4 ten inch woofers
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
yungdub
  • 93 Answers
SOURCE: Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Posted on Jun 14, 2009
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
MA 12 inch Hardkore Sub wiring
Go to rockford fosgate woofer wiring wizard and you will get your answer quickly by using the wizard,
Feb 27, 2013 | MA Audio HK15X2 Car Subwoofer
Wireing 12inch dvc 4 ohm subs
well rockford has a simple site to wire up your subs shows you how to configure them go to rockford fosgate woofer wiring wizard. and itll show you what you want to know..
Jan 03, 2013 | Rockford Fosgate Car Audio & Video
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
I have a rockford 500s i need a size for a sealed box for a crossfire bmf w12d. i am putting it in the hatch of a 96 camaro so preferably the smallest one. i cant go on crossfires website i only have my...
If it is a single 12" the rule seems to be 1 cubic foot of airspace. Fill a smaller box with fiberfill
and it thinks it's bigger.
If you want to compensate for the volume taken up by the woofer, you can use the following approximations. Keep in mind that these are for 'normal' woofers. If you're using a competition woofer with a huge frame and magnet structure, refer to the manufacturer for the actual displacement volume of the woofer. Even if you're not using competition woofers, most high quality manufacturers provide this spec in the woofer's datasheet. 8 inch .03 ft3 10 inch .05 ft3 12 inch .07 ft3 15 inch .10 ft3 Also noting that a box that is 12" X 12"X18" should get you in the 1 cu ft range but you may need
to go 14X14X14 or 1.3 cu ft to be able to get the speaker into the box-clearance!
Dont use plywood! It flexes. Use MDF and use a silicone sealer like window or door seal
to make it air-tight. To get more audio out of a small amp, add a port however the calculation
of port size is a bit scarse.
Here is the site I use. Maybe you can write down the www and go view it on someone's computer.
See # 110 on the right side pane. I love this site for all calculations.
http://www.bcae1.com/
Mar 11, 2011 | Rockford Fosgate Punch 500S Car Audio...
When i hook up my rockford fosgate subwoofers they dont work
Are you using an AMP and have you checked to see if anything is going to the woofers?
Mar 07, 2011 | Rockford Fosgate R1S412 Car Subwoofer
I have an AR s112ps subwoofer. I woofer is blown and i would like to find a replacement woofer. I havent had any luck looking on the net so far. any ideas?
all you need is an 8 ohm subwoofer or a Dual Voice Coil (DVC) 4 ohm subwoofer wired in series that can handle 120 Watts rms. I Went with a Rockford Fosgate Punch P1 P1S812 12-Inch 150-Watt Subwoofer - 8 Ohm
it was only $35 from amazon and is probably nicer quality than the original driver. Good Luck
Dec 24, 2010 | Audio Players & Recorders
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
I want to buy a AUDIOBAHN A2200HCT amp i have a kicker 17 15 inches this amp works with this woofer thanks
will work, ive heard mixed reports about those audiobahns though, i think personaly i would stick to phenox gold,rockford fosgate,or another well known power brand. what box is it in?
Feb 04, 2010 | AudioBahn A2200HCT Car Audio Amplifier
I have two zeus 1000 watts amps four rockford fosgate phase 2 15 inch woofers why my protect light keep coming on when i turn up my radio up
The power draw may be eccessive, try placing a capacitor (or a bigger one ) on the lines to the amps.
Message for the expert bobdunhay: You are not allowed to share your address.
Thanks.
Sep 10, 2009 | Hifonics Zeus Z1000D Car Audio Amplifier
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
32 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
