Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson vacuum cuts off
Vacuum runs a few minutes and cuts off. Restarts after 5-10 min. What is the solution for this?
  • 3 more comments
  • choneyb Oct 27, 2008
    My Dyson cuts off too after a few minutes and starts up again after 5-10 minutes. Is it overheating?
  • kc_661 Oct 29, 2008
    I have the same vaccuum. If I turn hold the "on" button it stays on, however if I don't hold it, it doesn't work. I just bought the vaccuum a few months ago.
  • dnyc1174 Oct 31, 2008
    It seems to me that it is over-heating when it shuts off,I have the same problem,and the suction isn t so good either.
  • Anonymous Mar 15, 2014
    Gets very hot and cuts out and have it on maximum suction
  • Anonymous Apr 01, 2014
    I just got the vacuum for Christmas. Its been fine until recently.when I turn it on it runs for 5 mins max before turning off. You have to let it sit for 20 min before it will turn back on. I've cleaned out the hose and it still does it.
  • 566 Answers
Hi this sound like a familiar problem of the motor o/heating due to lack of ventilation ? check the filters ok? remove the cover concealing the roller brush/beater and check for clogging at the underneath and housing clear it out properly easier to remove/lift out roller ? also clear out the clear bucket dust collector and most important the cone that fits into this canister has a cylindrical honeycombed/small holes(looks like hundreds? ) use a small pointed impliment to poke out all!!these holes as these are relative to vacuum within cylinder so if not clear ? motor no vent and result is no/poor vac and o/heat then thermo switch kicks in and shuts down till motor cools hope this helps best wishes from uk
Posted on Oct 31, 2008
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 07, 2013 | Dyson DC31 Animal Bagless Handheld...
Dyson Vacuum cleaner cuts out after a few minutes use
sounds like you have a blockage in one of the hoses and it's making your machine to over heat and cut out,check for blockages
Nov 06, 2012 | Vacuums
Dyson runs about 5 min then shuts off
REMOVE AND CLEAN FILTERS AND YOU MAY FIND IT WILL WORK OK IF STILL CUTS OUT YOU MAY HAVE A FAULTY THERMAL CUT OUT BLOCK INSIDE THE MOTOR HOUSING
THIS HAPENS WHEN DYSON IS USED WITH CLOGGED FILTERS AND HEAT DAMAGE TO THERMAL BLOCK
AVERAGE REPAIR COST £45 - £ 69 FOR NEW REPLACEMENT
Jul 11, 2010 | Dyson DC14 Full Gear Bagless Upright...
Dyson dc07 keeps cutting out after few minutes
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Stops after a few mins of use
You are experiencing a thermal cut-off - caused by a blockage. The machine turns itself off before it overheats. You will be able to turn it on again after 30 mins to an hour after it has cooled down. Call the Dyson helpline to do a full troubleshoot to find the blockage.
Jun 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dies after a few minutes of vacuuming
The thermal cut-off in your machine is activating - this indicates that you have a blockage or a clog in the machine. The machine will turn itself off so that the motor doesn't overheat - the machine will cool off and you'll be able to turn it on after 30 mins to an hour.
Call the Dyson Helpline for a thorough blockage check - they know what they are doing.
Jun 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
206 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
