Question about Nikon CoolPix S2 Digital Camera
My flash isn't working!
Coolpix S2 - and the flash isn't working. I have reset all the settings to default. The flash red light blinks indicating that the flash is 'charging' (ie not working) and you can't take a photograph except in 'landscape mode' when the flash is switched off. Can you cahnge a bulb or something - or is it more serious?
    Genius:
  • 2,985 Answers
Not a repairable situation here - the camera is a single piece. Nikon Technical Support will advise further.
Posted on Jul 22, 2007
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My camera won't take pictures with the flash on and when i try the red light just blinks. only takes pictures with no flash.
When your flash light (I mean the part that gives the flash) or the capacitor that stores the power for the flash are defect. you won't see a flash. When a red light comes on, when actually the flash should fire, the most likely the capacitor is defect. The electronics sensed it could not reach the voltage needed to fire the flash.
It also could mean your battery can't deliver enough to charge the capacitor, but is that was the case the battery indicator should tell you.
Jan 20, 2014 | Nikon COOLPIX S230 Digital Camera
I hve a nikon coolpix 10 MP but the image quality is poor....i have tried resetting all the camera settings to default and dont know what else to do....also, it keeps showing a red colored icon (it...
The red clock indicates that the date and time need to be set.
As for the "poor" quality, there are many possibilities. If the colors are wrong, the most likely culprit is an improper white balance setting. If the pictures are blurry, that could be caused by subject motion, camera motion, improper focus, or a combination of the three. If pictures taken with the flash are too light or too dark, that could be because the subject is outside of the flash's range. Without knowing what you mean by "poor" I can't give you anything more than some ideas.
Dec 27, 2011 | Nikon COOLPIX S220 Digital Camera
Coolplix S210 can't take photo in flash mode
The flash is trying to charge. Try a freshly charged battery in the camera. If that doesn't work, go into the options menu and set them to factory default. Try the camera again. If that doesn't fix it, there is a defect in the camera.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Help flash Nixon coolpix L11
hello,
make sure when you press the round selection button on the back of the camera flash option, you press the ok in the center of the button on the back.
it will show brief yellow AUTO in the LCD screen upper right corner for a sec.
when you are going to take a picture holding the shutter button half way down, you should see up at the right corner outside of the LCD screen a red led flashing to indicate flash is ready.
one thing to try if this is not working, find the camera reset option in the menu. after doing this you may have to reset the date & time. it will bring the camera back to default settings
on the bad side if these dont work, possible flash circuit may have failed inside the camera.
good luck!
Jun 13, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L11
I had the same problem with the Nikon 3200 Coolpix, the flash only worked with certain mode, as scene mode. I solved the problem doing a RESET ALL that is in SET UP menu.
Jun 12, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix S2 green lamp
Check the PDF manual on the software disk to be sure Nikon Technical Support for confirmation- this is a possible replacement situation
Feb 16, 2007 | Nikon CoolPix S2 Digital Camera
Nikon CoolPix S2 Digital Camera Logo
273 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
