Question about Frigidaire 24 in. GLD3450RD Built-in Dishwasher
Dishwasher only works on one cycle, and cannot select any other washing options.
Control panel with cycle selections on top doesnt seem funtional.
  • Electrolux
    Electrolux Feb 23, 2012
    Sounds like you have a bad control board and assembly panel. Contact your manufacturer to see if you qualify for any limited warranties.
  • 641 Answers
SOURCE: Lights flash but wont start
If the dishwasher is still under warranty, best thing will be to conntact for manufacturer service !! The problem you describe could be cause off : * A Defective switch level that doesn't "shows" that there is enough water in the dishwather and therefore will prevent program's advance. * A defective heater- If water will not reach need temperature it will prevent program's advance as well. * Defective timer - Dishwasher's heart. In case your washer is over its warranty period and you would like to solve your problem by yourself, let me know and I will instruct you step by step how to to find the defective part and how to fix it. Good luck !
Posted on Jun 09, 2006
  • 409 Answers
SOURCE: Won't start, can't change wash selections
hi there,
can you tell me if you can hear the motor running? if not
did you trip the house breaker? if not
can you open the door? if not
it's the door latch; if yes
is there water on the bottom of the dishwasher? if yes
you are not draining and the dishwasher lost power; if not
the timer is not advancing to the next cycle
let me know.
Posted on Sep 28, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 117 Answers
SOURCE: Our Frigidaire Dishwasher buttons stopped working.
You will have to replace that selector switch
http://tclaundryrepair.com/
Posted on Feb 20, 2009
mrbobfixit
  • 259 Answers
SOURCE: Dishwasher lights up but won't start
You most likely have a defective door switch or possibly a bad key panel. Frigidaire had a large quantity of door switch failures so I would start there first.
Posted on Jun 12, 2010
WFW9200SQ Cycle Control knob
Fixya cannot recommend part numbers.
Jul 27, 2017 | Washing Machines
I have a maytag top lading washer that was working fine. While filling the lid dropped. The only function that works on all cycles is the spin cycle. Can't get any water funtions to work. Suspect the...
What i suspect as being the problem is the lid switch asm....that assambly consist of 2 lid switches and a fuse which is wired through the water inlet valve so if it doesnt fill the fuse it very likely out and the reason the fuse went out is because one of the switches on the asm. is bad causing the fuse to blow.
GENE
Sep 08, 2011 | Washing Machines
Kenmore Elite Oasis HE Top Loader Washing Machine
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 18, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
The control panel works intermittently.
HI friend
it may be also timer problem .....did you touched it with wet hand...better to check timer,,,
thank u,,,,,,,,,
May 03, 2009 | KitchenAid Dishwashers
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Can not change Cycle setting
I wonder if it's the control board that needs replacing ??? found a note on www.managemyhome.com saying...(part no 134207700 according to my parts list). Is there anything unique/special in replacing the control board... here are the instructions for it...if you try this, pelase let me know...
Replacing the control board is just a matter of removing wires from the old control board and installing them on the new one. It is an electronic board and can be damaged by static electricity so you have to touch some ground points with you hands before touching the control board.
To access the control board remove the top panel from the washer. There are 2 screws in the rear of the washer holding the top on.
With the top removed you will see three screws going down from the top holding the control panel to the cabinet of the washer; remove them.
Lift the control panel up and it will come loose. The control is mounted to the control panel with some screws.
Oct 07, 2008 | Kenmore 44072 Front Load Washer
Whirlpool Top-Load Washer gvw9959kq
Yes. I replaced the control panel (the panel with all the cycle buttons on it). I downloaded the technician's manual from whirlpool and went through the troubleshooting to find the problem. Th part costs around $106.00. Just make sure you order the right color.
Jul 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Indesit DG 6100
the seal on the top drawer is damaged
Oct 05, 2006 | Indesit 24 in. D61 Free-standing...
Frigidaire 24 in. GLD3450RD Built-in Dishwasher Logo
408 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
