Question about Sony VPL CS1 Multimedia Projector
When i turn on the unit it light up but it flickers. and shows multipal pics
  • 10,594 Answers
Have you replaced its Lamp?
Posted on Oct 27, 2008
What could be the issue if my projector turns itself off after only running for 1-2 minutes?
It maybe a problem with your lamp as they can run for a short while then shut down.
When it shuts down do you get the lamp or temp indicator coming on?
Feb 01, 2013 | Sony VPL CS1 Multimedia Projector
I have the Sony VPL CS1 projektor and want to connect it to my tv, so that i can watch television channels on the big projektor screen, is this possible?
if your TV has video output signals for the program you are watching, then you can connect them to the projector.
otherwise you may need to get a cheap digital set top box and tune to the same tv program, and use the video output to feed the projector
May 14, 2011 | Sony VPL CS4 Multimedia Projector
My Sony VPL CS1 projector was working on Monday and is not working on Wednesday. Smells hot but fan is running. Light was on but now it is not on and the Lamp/Cover light is on.
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
Dec 22, 2010 | Sony VPL CS1 Multimedia Projector
Sony svga vpl cs1 projector horizontal roll
first of all open the projector and clean it form a bursh then cheack a losing if stips and jumpers thats it
Apr 24, 2010 | Sony VPL CS1 Multimedia Projector
Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
Apr 18, 2009 | Office Equipment & Supplies
Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
Mar 21, 2008 | Sony VPL CS1 Multimedia Projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Mar 14, 2008 | Sony VPL CS1 Multimedia Projector
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
Jan 17, 2007 | Sony VPL CS1 Multimedia Projector
Sony VPL CS1 Multimedia Projector Logo
207 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
