Question about Goldstar Microwave Ovens
Locating the mgt thermal fuse on goldstar MV-1515w microwave oven
I can't find the mgt thermal fuse
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: installation instructions for goldstar mv
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar manuals can be downloaded here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
Goldstar model MV-1515W over the range microwave. Runs everything works but won't heat and hums a bit louder than it use to. Anything I can do to fix???? Fuse, reset, throw away????
Please do not take offence to this answer. Please seek the advice of a qualified person because the capacitors in a microwave are dangerous. Handled wrong at best you will get a severe shock and minor burns at worse its lethal. I know what is wrong with it and a qualified engineer might charge about 80 pounds to fix but my conscience wont allow me to tell you in case it goes badly wrong for you.
Nov 16, 2013 | Microwave Ovens
1515w
You can order Goldstar / LG parts from Encompass here or you can call them toll-free at 866-779-5835.
The model number would be MV-1515W if it's white, and MV-1515B if it's black, but those parts will be the same in both versions.
If you're having trouble with the cooktop lights either staying on or not coming on after they have blown and been replaced, your need your control circuit board repaired. Details are here.
Jun 07, 2013 | Goldstar MV-1515 Microwave Oven
Gold Star 1515W microwave not heating up and when
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Goldstar MV-1515 Microwave Oven
Tray does not rotate and no heat at all
the thermal fuse (if present) is open. the motor is defective or shorte.
Aug 29, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar mv1502w has no power.Not even on display.
You can find the service manual here.
(Also, the owner's manual is here in case you want it)
I would suspect the magnetron thermal fuse / thermal cutout / thermostat (depending on which it has) or the oven cavity thermal fuse / thermal cutout / thermostat (depending on which it has).
To access some components, namely the oven cavity thermal device, you will need to remove the oven form the wall, in which case the installation instructions are very handy.
You can order L.G. parts from Encompass. Or you can call them toll-free at 866-779-5835.
Mar 14, 2009 | Goldstar MV-1515 Microwave Oven
Goldstar, MV1515W, builtin- fuse
it is under the casing, you need to remove the casing and you will see them, large power protection and smaller control circuit fuses. the power one may be protected by a black plast sheath
Feb 22, 2009 | Goldstar MV-1615 Microwave Oven
Installation instructions for goldstar mv 1515w microwave
Jul 30, 2008 | Goldstar Microwave Ovens
Goldstar microwave mv-1526 1000 watts
the bullet fuse to the klystron circuit may have blown
it is a thermal bullet fuse ,
google that to see what it looks like.
if you have a ohm meter it will give low ,closed resistance.
Apr 25, 2008 | Goldstar MV-1526 Microwave Oven
Microwave died
check control circuit and thermal protectors and check mains supply,
Nov 23, 2007 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
140 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
