Question about Samsung B2230 LCD Monitor
Remove back cover SAMSUNG B2230
Remove back cover
  • sergeys Feb 21, 2012
    i want to **** a blue light which is on when the monitor is off
    i want to turn off a blue light which is on when the monitor is off
How to remove back cover of viewsonic VT2430
Download the service manual from here:
http://elektrotanya.com/viewsonic_vt2430-1m_vs12335-1m.pdf/download.html
Apr 28, 2015 | ViewSonic VT2430 24"" LCD TV"
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
How to remove back cover ?
Before you remove the back cover, need to unscrew the nails from the back cover. then remove the keyboard (carefully remove the connector ribbon cable), then the top cover nails, after carefully removing the ribbon cables. Then the screws for the display panel. Remove the nails in the motherboard following the markings of the manufacturer. Finally you can take off the back cover separately as required. This procedure has to be followed and the experience is a must to avoid damages to the equipment. Get some professional advice before proceeding.
Jul 22, 2014 | ASUS Computers & Internet
Resolution issues with samsung b2230
did you installed your graphics driver if not install it first and you can change your resolution may be your system don't have that capacity you have to buy a graphics card that will fit to your system config and instal drivers it will work. hope that it will help you thanks
Feb 14, 2014 | Samsung B2230 LCD Monitor
Samsung b2230 volume
should be a "speaker" icon on bottom row. Otherwise go to settings.
Jan 30, 2014 | Computers & Internet
Audio card fro samsung model b2230
Not sure what you are asking for here, but this monitor does not have speakers/sound capabilities.
Aug 06, 2013 | Samsung SyncMaster B2230 22 inch LCD...
Removal of engine cover
Pry apart the back cover by guiding the flat-head screwdriver along the separating line between the front and back covers of the iPhone. When the back cover is apart from the front cover, flip the back cover off the iPhone, but be careful because a flat cable that goes to the motherboard connects the two covers.-----------------------------------------------------------------------------------
NEXIQ 125032 USB Link Plus
Jan 17, 2013 | 2007 Pontiac G6
I am not getting any sound from my new monitor
Check if the driver is working properly and if you have selected the specific device in your audio settings in control panel.
Sep 02, 2017 | Samsung B2230 LCD Monitor
When I was attaching the screen to a VESA arm, one of the nuts inside the unit came off and is floating in the unit. I need to get the back cover off to get the nut and re-attach it. How do I get the...
As it appears it seems that the back of the unit is held together by clamps. I wouldn't advise you to go ahead with the dis-assembly because you risk breaking the clamps. But if you must do it proceed with caution. Start prying open from the bottom screws toward the top of the unit. Use a plastic wedge to help the prying. It really comes down to finesse and experience. If you don't feel confident doing it don't do it as you might break it irreparable. The mount should be usable even mounted in 3 points.On the other hand the loose nut could cause some damage short circuiting the board. \
Good luckVlad
Feb 27, 2012 | Samsung B2230 LCD Monitor
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
Samsung B2230 LCD Monitor Logo
70 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
