Question about Hunter 23852 Classic Original Ceiling Fan
I have a hunter original fan that will not reverse. I can feel a vibration or hum when the fan is on but the blades will not move or move very slowly. When i push the reverse switch it works but in th
This is the cast iron original. It has a pull switch to change speeds which is working fine.
Sometimes dust will accumulate around stem and down in the motor. Clean with a few quick shots of air.
Posted on Feb 21, 2012
4 Suggested Answers
  • 57 Answers
SOURCE: My cast iron original hunter ceiling fan needs a
Howdy,
There are a couple of issues which can cause this with the Original. First, is this an American made fan, or a Chinese made fan? The main difference between the two is the motor type. The Chinese version should have an "A" after the model#.
First question, when you turn the fan off, how long does it take to come to a stop? From high speed it should take at least 60 seconds, from low at least 20 seconds or so. Also, are you trying to start this fan from a wall switch on low speed?
The first issue which can cause this is oil level, I know you say it has plenty of oil, but, depending on how you checked it, it may not be enough in the reservoir. To check it, you take a pipe cleaner and bend it over to form a J with the hook portion being 3/8"-1/2" long and dip it into the oil cup at the top of the switch housing as said in the below links. Remember, if you have a Chinese fan from 2002-2007 (after 2007 there is a brass cap on top of the motor where you add the oil and it functions the same as the American fans), the oil hole will be on the switch housing and you must lean the motor over to add oil, if you add it with the motor level there will not be enough oil in the reservoir. If you are indeed full of oil, run the fan on high, and with a LARGE screwdriver used as a stethoscope, remove the switch housing cap (two screws) and insert it all the way to the top of the switch housing and put your ear to the other side of it, then turn the fan off and while it coasts down listen. You should hear very little noise if anything at all, it should be totally smooth oil if circulating through the oil system, if it sounds dry and gritty or like metal on metal, then oil is NOT getting to the top of the armature. If this turns out to be your problem, I can help you fix it.
The second issue which could cause this, is the capacitor is getting weak and the motor isn't generating enough torque to start. I think this is fairly unlikely as I have never seen an Original with a bad cap.
The third issue could be that, if the oil is where it is supposed to be and if you have tried putting an extra snort in the oil hole and that doesn't cure it, that something has gotten into the oil reservoir and is binding the bearing up. Bugs seem to love the oil cups of these fans for some reason and I have discovered wasps, beetles and flies in the oil cups before when dis-assembling these fans for repair. If you have exhausted the other possibilities, remove the fan and drain the oil out of it, shake the fan a few times to make the rotor bang back and forth and then re-install the fan and re-fill with new 10wt oil. (do not use 3-in one oil in either the red or blue can, both of which contain napatha)
If you have the American made fan, this is the owners manual http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41532.pdf
If you have the Chinese fan, this is the owners manual for it http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/41556.pdf
If this is an American made fan, it's worth repairing, if it is NOT an American made fan and after troubleshooting it and not finding a fix, I recommend calling Hunter and warrantying the unit out. The motors carry a lifetime warranty.
Posted on Dec 23, 2010
Testimonial: "Thank you. The fan is running great now! It is the American fan. Bugs must have been the problem."
Richie_asg1
  • 1036 Answers
SOURCE: hunter ceiling fan
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
djgoodson
  • 17 Answers
SOURCE: dont know how to remove blades
look as far up as you ca... it may be one of those fans that the whole thing is attached to each other... my dad had to take the whole thing down one time in order to unscrew them
Posted on Apr 02, 2009
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
Can hear humming noise, when switch is on but the fan will not turn. It is locked up.
Begin by checking the forward/reverse switch, (sometimes called the Summer'Winter switch), there is a good liklihood the switch is stuck between positions.
If you can manually spin the blades in either direction your fan is probably not locked up.
All the best.
Nov 21, 2010 | Hunter 23852 Classic Original Ceiling Fan
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
The fan makes noise and vibrates when it runs
Howdy,
First off, is this a newly installed fan, or an older unit? These fans use oil for lubrication of the bearings, is the reservoir full of oil? Are the blade brackets which hold the blades to the motor loose? Check those screws and the oil level. Here is the owners manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
Sep 16, 2010 | Hunter 23827 Classic Original White 42"...
Dont know how to remove blades
Apr 02, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling fan
Jun 11, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Hunter 23852 Classic Original Ceiling Fan Logo
269 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
