Question about HP Designjet 110plus nr InkJet Printer
Printhead errors I am getting a 79:04 error and a Start-up cycle error of 167. Regular screen shows the Yellow and Magenta printheads flashing. Those were replaced brand-new 2 days ago, and they initailly gave a good printhead alignment. Now, I cannot get past the opening error.
  • trevorsadd Nov 10, 2008
    We've got a problem with the blue print head flashing and the printer not working. We replaced the print head a month ago and it solved the problem. Last week it started flashing again and we replaced the print head again (with another new print head). It just keeps flashing we've reinstalled the software, cleane dthe head, refittted the parts, turned in on and off a few times.
  • san4161 May 07, 2009
    We've got a problem with the yellow print head flashing and the printer not working. We replaced the print head a month ago and it solved the problem. Last week it started flashing again and we replaced the print head again (with another new print head). It just keeps flashing we've reinstalled the software, cleane dthe head, refittted the parts, turned in on and off a few times.
    Problem Solver:
  • 9 Answers
Sounds like a carridge issue , check that the carridge can move freely and theres nothing stopping it
Posted on May 08, 2009
System error 1254
System Error 1254 Sub-Tank Supply Error, print head #4 may be defective or out of ink.
Problem
Description:
The Sub-Tank Sensor does not switch to less than half even though ink has been
consumed.
?? x = 0: Printhead Number 1 (Black).
?? x = 1: Printhead Number 2 (Light Magenta).
?? x = 2: Printhead Number 3 (Light Cyan).
?? x = 3: Printhead Number 4 (Yellow).
?? x = 4: Printhead Number 5 (Magenta).
Here is a link to the HP troubleshooting manual for this printer on pdf
http://www.partshere.com/models/Q6665A/Q...
Jul 13, 2014 | HP DesignJet 9000 InkJet Printer
Error 1252 power/on and off
System Error: System Error 125x: Sub-Tank Supply Error
Problem
Description:
consumed.
x = 5: Printhead Number 6 (Cyan).
Corrective Action: Try the following:
Enter the Motors Menu (in Maintenance Mode) and set the "Solenoid L"
and "Solenoid R" options to "Closed" to cut the outside air. Now set the
"Cap Stat Motor" to "Prime" to discharge the ink from the Sub-Tank and
check if the Ink Supply Motor drives by turning the power ON again when
there is a little bit of ink left. If the Motor is not driven, replace the
corresponding Cable or Ink Supply Station.
Check whether the Sub-Tank Sensor Plate works correctly and is not
blocked by any foreign object.
Apr 18, 2013 | HP DesignJet 9000 InkJet Printer
1.hp desighnjet 500 showing an exclamation marn on magenta printhead 2. error 59.99 on hp colour laserjet 3700
The exclamation mark means that the magenta printhead is already low in ink or have encounter a problem. Try removing and reinstalling the magenta printhead, if that didn't work, you will need to get a replacement for your magenta printhead since it could be low in ink.
Sep 21, 2011 | Office Equipment & Supplies
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
MP780 printer doesn't show red color, I replaced a new Magenta color toner, but it didn't show any red color.
Go to printer maintenance and perform deep cleaning,do it for 3 times the if it doesn't clear the error, try to look for a chemical solution that can be use to unclogged printhead. Remove the printhead on the printer then soak it but don't dip the whole unit it might got wet the board of the printhead. You can also put some cleaning solution on your old cartridge without removing the printhead on the printer. You must put the solution of course on the magenta only. Let it there for 12 hours then perform a test.
Sep 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
9,035.4x through 9, 038:
Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Jan 10, 2008 | Lexmark C752 Printer
Lost yellow but "maintenance" gave no diagnosis
sounds like a clogged printhead but I would try the tech 3 to make sure. 800-474-6836
Apr 20, 2006 | HP DesignJet 10ps InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
468 people viewed this question
Seeker5211
Seeker5211
