Question about Music
Own a casio Priva 800 keys no sound on some key other hard to press down
Some 4 white keys very hard to press down ,some black keys no sound can they be fixed
  • 374 Answers
SOURCE: casio ctk 496 keyboard
Unplugging and taking batteries out for 15 minutes should reset it back to factory.
Posted on Sep 12, 2008
bruce508
  • 44 Answers
SOURCE: CASIO CTK-800 turns on but no keys work
That doesn't sound good. It sounds as if the processor is locking up and that might only be fixed by replacing the main board. Sometimes this happens if a unit gets fried by static electricity.
But before giving up, I would open up the unit and check for loose cables and connectors internally. If there are chips (IC's) that are socketed on circuit boards, push them down firmly. Things may start working again.
Posted on Jul 02, 2009
  • 5603 Answers
SOURCE: My casio ct670 ToneBank keyboard isn't making much sound
Check that you don't have old batteries in the unit. Also that the auto power down is not activated.
If using a power adapter make sure it is the RIGHT one, both in polarity and current rating.
Posted on Sep 22, 2009
Testimonial: "Sorta helpful. How do I check for auto power down activation? Thanks for responding so soon. I'm not using batteries and used the original ac adapter."
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
What is causing noises in my Casio privia Digital piano?
Pivots worn out or need lubricant. Make a warranty claim first.Otherwise, If out of warranty I would try to lubricate the hammer pivots myself. You will need "grease suitable for plastics".
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
What is causing noise in the keys of privia px350?
Try using a can of pressurized air to clean around the keys that are noisy.
The lower keys wont work without harmonization
Sounds like you have the accompaniment function selected. Find the button on the front panel and deselect it and you will get full control back
Feb 01, 2014 | Casio Keyboard Power Adapter
Sound stuttering
Hi, This and a lot of similar keyboards have gold flashed pads on the PCB and the keys press one or two rubber caps, with conductive pads in them, down.
Clean the pads with isopropanol, (and nothing else) and it will be cured 99% of the time. If a few notes do not work, especially after heavy use, then the rubber caps can be replaced.
Taking the keyboard apart is long winded because of the number of screws involved.
The job its self is simple enough, but take note of the order things go in and where the screws go.
Hope this helps, Chris.
Jan 09, 2014 | Casio Music
Problem with casio CTK-691 keyboard
"can I do it my self or should I go to a professional to get it repaired"?
Get it repaired by a professional. Casio gives long warranty (5 years in Australia). Mine took weeks for Casio Service to repair. Many boards had to be changed.
Jan 25, 2012 | Casio Ctk691 Keyboard
I have a priva PX-410R, when I turned it on today just one of the keys is playing at full volume like I was pressing the key really hard. The rest of the keys are playing normally. If I put it on say a...
Each key has two contacts. One closes first and then the other. This allows the processor to measure the key velocity which is then used to control volume. The key contacts are conductive rubber "pills" pressed onto circuit board traces. Clean them ONLY with 99% isoprophyl alcohol and Q tips. The disassembly of the unit to access these is NOT for the inexperienced so you might want to take it to a repir shop. Here is a service manual for a Casio 811 which is totally different packaging than yours, HOWEVER the keyboard itself will be similar and you will get an idea what is involved with getting into one of these things:
http://elektrotanya.com/casio_ctk_811_ex.pdf/download.html
Scroll down to "get manual" and click to download... IGNORE other download links.
The keyboard exploded view is around page 32 in this manual.
Aug 03, 2011 | Music
Casio CTK 800 spare key
I can think of two places. eBay search for
Casio LIGHTED KEY KEYBOARD or call casio and explain to them what happened and see if they can help :) Steven.
Apr 14, 2010 | Casio Lighted Keyboard LK90STADMC
Nov 30, 2009 | Casio Music
Music Logo
41 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
