Question about GoPro HD Hero 960 Video Camera
Stuck in video mode
Gop pro hero 960 stuck in video mode, not possibel to turni it off nor open settings. It is not in one button mode, both buttons beeps, LED and number in the screen flashes, but nothing happens after pressing buttons.
I had the same. I plug it into the computer and unplugged it several times, took out the micro SD card. Finally it said "no SD" after a while. Pulled out battery and put back in then plugged into computer again, and back to normal it seems. Sorry this is not a step by step but I was just trying random things till it worked. Did not re-test to see if it is OK for the next recording session.
Posted on Mar 24, 2013
My Yamaha Rx a710 is stuck in stand by mode can't get any thing to work how do I do a hard re set on this receiver
  1. Set the unit to Standby Mode using the Power button. ...
  2. While holding down Straight button, hit the Power button. ...
  3. Use the Program Selector buttons to navigate to INIT-CANCEL and press the Straight button to select INIT-ALL.
  4. Turn off the unit using the Power button
Oct 20, 2016 | Yamaha Audio Players & Recorders
Why is the blue fret button on Guitar Hero 2 is stuck in down position?
Perhaps the micro switch under the fret button is faulty. return it to the shop and have them test it.
Jun 30, 2014 | Activision Xbox 360 Guitar Hero II
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
Apr 09, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
How to set correct time in the digital clock of Hero Honda CBZ X-treme?
remove the battery and connect exactly at 12:00AM,
then the clock shows the time as 12:00AM,
no other option is there..
May 04, 2012 | Hero BR1R CR 125 Motorcycles
Will not turn on have changed the batterys but still no go only had the camera since xmas
I have had go pro 960 camera for 2 years has worked fine till now . Now it won't turn on charged and changed batterys ,still nothing. Help please
Mar 22, 2011 | GoPro HD Hero 960 Video Camera
Go Pro Hero HD camera, some video and pictures have pink colour, but just random not every time.I don't know if is broken, or software problem. Maybe you now this issue and have a solution. Thanks,...
you may have an issue with white balance, try takeing a shot out side and then take one inside with different light such as tungsten or neon light, and see if one of these light levels is showing the pink replay. you will have to set your white balance accourdingly for the light you are in. I know that there is an update firmware for the camera that resovles this if it is a pre 960 version camera, check the go pro website for more details.
I hope this was helpful
Mar 16, 2011 | GoPro Digital Hero
I have a brand new Go PRo Hero Naked 1080P HD camera. In my initial attempts to familiarize myself with the camera, I noticed 2 things: 1. when I turn on the camera, the default start mode (which is...
You can choose your default power up mode in the settings menu. If it's already setup as F (film), then you're holding the power button too long when turning on the camera (if you hold the power button, it will turn on in the next mode after the default power up mode). Try just quickly pressing the power button - this will remedy that one if your default power up mode is already set to F (otherwise, go into settings menu and change it to F).
A couple of my friends' computers don't have the RAM/video card, or whatever is needed to playback HD footage smoothly. There's a ton of data transferring to playback the HD video/audio, and many computers (especially if they're not new, but even many new ones) aren't up to the task. Try playing it from the camera to your TV. Does it play smoothly? If so, it's the computer. This doesn't effect videos you upload to YouTube, etc, it is just frustrating and annoying that it doesn't play smooth and makes editing slower as well. Check out the support page on gopro's website - they have FAQ's, Troubleshooting, etc... tons of helpful info there. Also, most of us who have used gopro gear for a while now are usually happy to help when we see a question we know something about.
Dec 28, 2010 | GoPro HD HERO Naked Wearable Camera
1995 volvo 960 stuck in winter mode
Where roy might have a possible source, it is most likely the park neutral switch which has started to fail. This is indicated by the shift arrow flashing on the dash. Replacement of this component is relatively difficult without a lift
May 11, 2009 | 1995 Volvo 960
Stuck in Video mode
Good day.
Have you tried changing the settings through the buttons on your unit? they may be able to assist you in this problem.
chris
Mar 22, 2008 | Sanyo DS19310 19" TV
Camera-video mode
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Apr 09, 2006 | Fuji FinePix 2650 Digital Camera
GoPro HD Hero 960 Video Camera Logo
230 people viewed this question
Top GoPro Home Security Experts
Lawrence Oravetz
Are you a GoPro Home Security Expert? Answer questions, earn points and help others
