Question about HP C6280 All-in-One Printer
My hp c6280 says error 0xc18a0501. how do i fix it
It said first i had to change 2 cartiges, i changed them and then i needed to change a 3rd! when i changed that one it gave me the error
  • 13433 Answers
SOURCE: NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Posted on Jul 05, 2008
  • 84 Answers
SOURCE: Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Posted on Jun 02, 2009
nalin_elliot
  • 224 Answers
SOURCE: HP C6280 Error Oxc18a0305
Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
This should work
Posted on Jun 16, 2009
pineworks
  • 4041 Answers
SOURCE: Error:0xc18a0501 on HP Photosmart 3210
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
SOURCE: MY hp c6280 says error 0xc18a0106. What does that
ME APARECE Error 0xc18a0001 que devo hacer para que se arregle mi impesora, saludos gracias
Posted on Aug 22, 2010
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
Its giving error code 0xc18a0501 ink system failure.how can i fix this?
If systems problem, just install and reinstall the printer software to correct the setting.
Dec 07, 2010 | HP Photosmart 8250 InkJet Printer
Jul 22, 2010 | HP C6280 All-in-One Printer
Hp c6280 error code 0xc055d0381.. need defenintion of error
This error codes indicate that the product has an internal error condition. We need to reset the printer to fix it.
  1. Without turning OFF the printer disconnect the USB cable from the rear of the product.
  2. Removed the ink cartrigdes and wait for "insert cartridge message to display.
  3. Disconnect the power cord from the back and wait for 60 seconds.
  4. Reconnect the power cord. If the product does not automatically turn on, press the Power button
  5. Reinsert the cartridges, and then close any open doors on the product.
  6. If you receive a prompt to print a calibration page, do so.
  7. Reconnect the USB cable to the rear of the product, and then try printing again.
Regards,
Riztech
Mar 04, 2010 | HP C6280 All-in-One Printer
Reset the product:
5. Wait 60 seconds.
Jan 31, 2010 | HP Photosmart 3210 All-In-One InkJet...
Jun 02, 2009 | HP Photosmart C6280 Printer
Cannot run c6280 all-in-one printer from my computor, just got printer back from warrenty repair
you may have 2 options:
1. if you use USB cable in order to connect your PC to the printer.
you may need to change to another port of USB cable from your computer.
2. if you use Ethernet port, (and/or pct. 1 does not work) you may need reinstall the driver for c6280.
3. if pct. 1 or pct. 2 does not work, you must go back to the service. (again)
Sep 23, 2008 | HP Office Equipment & Supplies
HP C6280 All-in-One Printer Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
