Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
E19 error message Canon MP140 PIXMA? - Canon MP140 PHOTO AIO All-In-One InkJet Printer
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
No puedo instalar mi impresora canon pixma mp 130 por perdida del cd de instalaciòn, como me pueden ayudar gracias.
Posted on Apr 27, 2008
  • 412 Answers
SOURCE: my canon pixma mp140 error 2 and the alarm light
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Mar 09, 2009
  • 412 Answers
SOURCE: Canon PIXMA MP140 Service error 5100
ok... you have to reset the printer --
Hpoe this helps
  • 566 Answers
SOURCE: how to install canon printer MP140 without a disk
You can download the drivers and software for your printer from CANON:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15294
Click on the "Drivers and Downloads" tab and then select you OS.
Posted on Aug 19, 2009
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How to fix error 24 for mp 160????
Hi
This is a purge unit error hence you need to check and make sure the purge unit is working fine. If not you need to clean it.
THE PURGE UNIT IS THE ONE ON THE RIGHT SIDE WHERE THE CARTREIDGE RESTS WHEN YOU TURN OFF THE PRINTER.
And at the same keep the below mentioned error list for your future use.
CANON MP140, MP145, MP150, MP160 ERROR CODES RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E3-3 = Paper jam
E4 = No ink
Direct Printing
E29 = EEPROM error
Jul 31, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Multifuncional mp140, result error 4,2 and then error 5010 solution?
canon mp140 i get a error code 5010 any suggestions on how to fix this?
Apr 25, 2011 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP140 - c light flashing
This means you are getting low on color ink. You can continue printing for a while, but eventually you will get an error message (E,4) indicating that the ink has run out. Purchase, or have ready, a new color ink cartridge.
Feb 20, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Cannon mp150 error 2 message what does this mean
error 2 probably means out of paper - thats what it means for my pixma mp140
Apr 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
187 people viewed this question
old marine
old marine
