Question about Toshiba Satellite A135-S4527 Notebook
Booting problem windows xp comes on when powered up and looks like it is trying to boot up but then it goes to error (fatal system error) and then shuts down the system. what could be the problem?
  • Puneet Jain
    Puneet Jain May 11, 2010
    Are you able to boot in Safe mode? Have you try tapping up F8 Key during start? If you have installation or Recovery Disc then use it to repair windows..
    Let me know if you need further help!!
    Guru:
  • 558 Answers
Let me know if I can further assist you, otherwise please rate the solution. Thanks
Best of Luck & Have a Nice day.
Scott,
Posted on Oct 30, 2008
  • 36 Answers
This is most commonly a corrupt file due to viral infection or registry entry. i would recommend restore to last known good configuration then run a thorough virus scan. if unable to restore try the repair option on your windows xp disk
Posted on Oct 29, 2008
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Compaq Preario V5245eu cant get past scrolling xp window just restarts and doesn'r get anywhere have had a c000021a fatal error warning- help please Rodger
If you attempt to install a piece of hardware or software on your PC computer that is incompatible with your system, you may see a blue screen with a C000021a fatal error warning. The easiest way to recover the Windows operating system from this type of error is to restore your computer to a previously working state.
1.Press the "F8" key on your keyboard when prompted during the boot process.
2.Use the up-and-down arrow keys to highlight the "Last Known Good Configuration" option. Then hit "Enter.
3.Use the up-and-down arrow keys to highlight the operating system version that you wish to boot up to, and then hit "Enter" again. The system will now restart to the last working version of your operating system, which will eliminate the C000021a fatal error.
Hope this helps
Mar 13, 2010 | Computers & Internet
Having a problem with my gateway comp. using
  1. Boot to your XP CD, enter Recovery Console and run the command CHKDSK /R and see if that resolves
  2. Run diagnostics on the HDD, it may be failing, replace HDD if diags fail
  3. In-Place (Repair) reinstall of WIndows http://windows.microsoft.com/en-us/windows/help/install-reinstall-uninstall
Jan 25, 2010 | Microsoft Windows XP Media Center Edition...
Philips laptop has fatal error message - system
Hello Vixen,
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try.
And they are going to be two Options.
First options is this:
If you have a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10) required to enter setup, while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from.
then follow the On-Screen instruction and select repair.
Next Option is if you don't have the Windows Installation CD.
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to select the different options of booting.
First of all try out "Last Known Good Configuration".
If it doesn't work, then try booting into safe mode.
If it boots in Safe Mode, then click on start---> Accesories--->System tools---> then System restore. Then restore you system to an earlier time.
Now, If all that still doesn't work, then Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /p and press enter.
This will scan your system for errors and correct it.
If this does not work, type scanreg .
This will scan your systems registry for errors and fix it.
If Trying All these does not work, then Go back to Option 1.
Which means you will have to get a Windows Installation CD.
I am giving you all this trouble-shooting steps with the assumption that you are using Windows XP. (Because you did not specify your type of OS).
But In case you are using Windows Vista,
then under option 1, after inserting the CD, and booting from it,
just follow the on-screen instructions and select:
"Fix what is preventing my Windows to boot Properly" , under the options.
All these are the FULL trouble-shooting steps you will need to get your system working.
But if after trying all of them out it still does not work,
Then you will have to take them system to a good technician.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Nov 25, 2009 | Computers & Internet
Windows 98 won't boot up
Can you run Win98 in Safe Mode? Just tap F8-F10 or Del or Esc on booting (It's different buttons on different machines) to enter Advanced Settings and run Win98 in Safe Mode. You can get access to your files, and maybe even System Restore back to a point before you had the problem?
Worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Microsoft Windows XP Home Edition
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Blue Screen of Death
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Dec 16, 2008 | Acer Aspire 5050-3242 Notebook
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Nov 19, 2008 | Compaq Presario Notebook
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
I keep getting a blue screen that says fatal system error. My computer is a toshiba satellite x205-s7483. Th computer wont start up and takes forever but when it does the computer runs slower, freezes or...
it is a fatal error mostly occured in windows like xp. it is also the prevention of disturbing with the memory.
we have some tips to recover from there. first you have try to boot as last known good configuration option in the windows startup option. (you press F8 key, when the computer boots up).
if it is not working, try to boot in safe mode.
if it is also not possible, you have to go with your xp cd or operating system cd. first boot with operating system cd and go for the repair option to recover your operationg system.
Jul 21, 2008 | Toshiba Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
