Question about Kitchen Appliances - Others
I have an B & D 2200 and the bread isn't rising and it is burning.
The bread is only rising tho half the capacity and it is burning.
One of two things come to mind............
The house is too cold or,
You're not adding ingredients in the EXACT order as recommended
Posted on Oct 31, 2008
How do you use proofed feature
If I understand correctly Carol, you want to know about the 'prove' feature on your oven?
In bread making the proving part of the process is where low heat is makes the bread dough rise. It is a barely warm setting just about blood heat. It makes the yeast release carbon dioxide bubbles which makes the bread rise.
Nov 18, 2015 | GE PB910TPCC Profile Freestanding Electric...
I am using the old recipe from my 20 year old Black and decker book, in my new new B & D bread maker and it falls flat on top? In the old machine it rises beautifully and stays there, why? new bread...
You may find that one machine (the old one) stipulates Active Dry Yeast and the other one (new) stipulates Rapid Rise Bread Machine Yeast. What are the main differences from your old recipe and a similar recipe in your new recipe?
Jan 18, 2011 | Black & Decker Bread Machine
My bread maker kneads twice just fine, and it bakes just fine, but the bread doesn't rise very high. All of my ingredients are fresh. I have tried several different recipes and it still doesn't rise in...
That is a difficult problem. One thing you might try to get a better rise in your machine is to cut the salt in your recipe by one half. It's healthier that way too. Please let me know the result.
Jan 07, 2011 | Oster 5838 ExpressBake Bread Maker
I just purchased my bread machine and was excited to use it so i tried to bake whole wheat bread... i followed all the instructions and exact ingredients but my bread turned out undone... the top was not...
Don't get discouraged. Most new users of bread machines make some mistakes in the beginning.
Some things to remember: Don't lift the lid and peak inside... you'll let heat out especially during baking....recommend rapid rise yeast not active dry....I use half the salt recipes call for especially with whole wheat. Recommend you try some recipes first with unbleached bread flour, basic white bread recipes so you'll get a good rise and get your confidence up and then try whole wheat.
Maybe some of these tips will help ....
Nov 24, 2010 | Black & Decker Bread Machine
Frequently the bread does not rise correctly when doing "fast" mode.Should the unit be heating during the rise cycle?
Bread not rising correctly is complicated since there are so many factors involved more than just proofing temperature. You should hear a short click once in a while as it cycles the heater on for just a second at a time. You won't notice any considerable heat since too much heat will kill the yeast. Bread not rising correctly is normally due to the gluten not being developed in the bread or the flour was poor quality without much gluten to begin with. You can try adding some "Vital Wheat Gluten" to each batch to help and at the same time adjusting the yeast up by a half teaspoon at a time. Also keep in mind that the salt you add to the dough will ****** the yeast. Try and limit the salt to a teaspoon per loaf. Too little salt and the taste of the bread will go bland on you. Another aid to rising is to add some Diastatic Malt Powder to assit in the rise. And lastly, remember that you whole wheat flour will never rise as high as white flour.
Nov 20, 2009 | Breadman TR875 Bread Maker
Dough wont rise . everything else works
We perserved for 6 months and found that the drive shaft was worn out. The shaft wobbled very slightly. We baked several windowless buildings (bricks) before we found this out and bought a new shaft for under NZ$80. Hope this helps.
Jun 02, 2009 | Panasonic SD-YD250 Bread Maker
The bread only rises about half way.
After its mixed the ingredients and before it cooks, it should sit for a while to allow the mix to rise. Check that the heater is on in this period, otherwise, if its cold, it wont rise
Feb 14, 2009 | Betty Crocker BCF1690 Bread Maker
Bread won't rise
We have owned a Panasonic bread maker for ten years and gets used twice a week to make bread using "spelt " flour.About three years ago the bread maker was producing flat loaves,and was very heavy.We contacted bread making company called "Simply No Knead"and asked for there advise,as we were following the same recipe and method for around six years. They suggested that we add a little more water,and this would fix the problem.We tried this and the bread still failed to rise,so we rang them again .This time they said that we need a new bearing in the bread maker and that would fix it.We did this at a cost of $40 and still no good.This happened over a period of several months.We suggested to them that there must be something wrong with the flour,which they denied.After checking the labels on the packaging we noticed that they were using flour from another country [ I think it was Hungary ],because they had run out of suppies from Australian wheat produces.
The flour was far to old,and bread won't rise if the flour is to old. As soon as they started using Australian produced flour again the bread improved dramatically.
Hope this is helpful to you
Dec 11, 2007 | Breadman TR875 Bread Maker
Wheat bread problems
I had similar problems until I tried the recipe listed on the King Arthur Flour web site. I discovered using less flour is always the better option and they say to cook on the white setting even tho it is a wheat flour recipe. I have had good luck with the King Arthur white wheat flour.
Jan 06, 2007 | Zojirushi BBCC-X20 Home Bakery Supreme...
Kitchen Appliances - Others Logo
50 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
