Question about Ovens
Hi i have a zanussi zce7610. the grill was only heating around the edge so we replaced the element, it still didn't work so we thought it must be the thermostat. still not working. no light comes
Zanussi zce7610w grill not working have replaced element and thermostat still nothing. no lights come on either when turned to either grill or oven
SOURCE: Main Oven does not get
Called Engineer in the end, Heating element needed replacing
Posted on Aug 15, 2008
  • 1462 Answers
SOURCE: delonghi esf461st oven not heating up
grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
Posted on Sep 06, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
  • 44 Answers
SOURCE: i turn on my Technika electric oven (TB60F) and
hi
behind the panel at back of oven is the fan and around that is a fan element the changes are this will be you problem . just remove panel and check weather the element has burnt out
regards
Posted on Mar 19, 2009
  • 77 Answers
SOURCE: Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Posted on Nov 28, 2009
Our ancient Zanussi ZSA15 oven isn't working. Everything else is - lights grill etc. Guess it sounds like the element around the fan. Can I fix this (unlikely), is it worth replacing?
ONCE AGAIN, A SIMPLE GOOGLE SEARCH!
I WISH PEOPLE WOULD LEARN TO USE IT INSTEAD OF BOTHERING US!!!
Zanussi ZSA15 oven parts
Google
This is the official Zanussi parts website.
Click on Cooking then select heating elements.
Official Zanussi Site Parts Accessories for Appliances
You'll need to find your Appliance Product Number, the page tells you what to look for.
On this website, your ZSA15B or ZSA15W (probably stands for black or white) Is listed. It lists 3 different replacement elements.
Zanussi ZSA15W Elements
Sep 21, 2016 | Zanussi Ovens
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
ZANUSSI Oven E025
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
May 15, 2010 | Zanussi ZBF360 Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Oven not working
Dec 19, 2008 | Zanussi ZHQ575 Electric Double Oven
Grill not heating up properly on my zanussi oven
Hi.
Sounds like you have only got half the element working. some ovens have 2 seperate elenents forming the grill. Check if this the case.
Nov 19, 2008 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
