Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the
Toshiba Hotkey Utility, and then reinstall it.
This program is called
E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called
Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
Click Start.
Click Control Panel.
Double-click Add or Remove Programs.
Select TOSHIBA Hotkey Utility.
Click Change/Remove.
Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
Select E-key Utility from the list, and click Install.
When the WinZip Self-Extractor window appears, click OK.
Click Unzip.
Click OK to acknowledge that the files were successfully unzipped.
When the InstallShield window appears, click Next and follow the prompts to complete the installation.
When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
- Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
Navigate to where you saved the file and double-click it.
- Click Run.
Click Unzip.
